I boot with SDK manager,But there were some errors that occurred:/misc/tsc_controls/tsc_locking_adjust_configuration is not supported
Which JetPack SW?
JetPack 5.1.3
It seems there’s something wrong in your device tree.
Do you modify anything in BSP package before flash?
Please provide the <Linux_for_Tegra>/bootloader/L4TConfiguration_updated.dts for further check.
I did not modify the file, and now I have downloaded 5.1.4 again, but the installation still fails. Is it normal for the power indicator light to turn off during the flashing process of the motherboard. Then, I couldn’t find the files you mentioned.
Are you using the devkit or custom board for Orin NX?
It shows in your screenshot.
Please share the full logs exported from SDK manager for further check.
