Hi all
Can’t resume after suspend with 535 driver on OS: Linux Mint 21.3 x86_64
Kernel: 5.15.0-118-generic
l am experiencing an issue where your Linux Mint 21.3 system can’t resume after being suspended when using the nvidia-driver-535. with NVIDIA drivers on Linux systems. Let’s clarify the situation:
My system boots up normally with the NVIDIA driver installed.
When l put the computer to sleep (suspend mode), it appears to enter sleep mode successfully.
meaning When you try to wake the computer from sleep, it fails to resume properly. it stopped to resume with black screen with all system information displayed on the screen, then l need do nothing until I hard-restarted o options
this is very frustrating,
I’m happy to provide further information about the system
Thanks in advance for any assistance you can provide.
@Inspiron:~$ nvidia-smi
Fri Aug 9 11:12:52 2024
| NVIDIA-SMI 535.183.01 Driver Version: 535.183.01 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 960M Off | 00000000:02:00.0 Off | N/A |
| N/A 41C P8 N/A / 200W | 6MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1209 G /usr/lib/xorg/Xorg 2MiB |
inxi -Sx
System:
Host: Inspiron Kernel: 5.15.0-118-generic x86_64 bits: 64 compiler: gcc
v: 11.4.0 Desktop: Cinnamon 6.0.4 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
inxi -Gx
Graphics:
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Dell driver: nvidia
v: 535.183.01 bus-ID: 02:00.0
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-4:3
Display: x11 server: X.Org v: 1.21.1.4 driver: X:
loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa gpu: i915
resolution: 1: 1600x900~60Hz 2: 1600x900~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2)
v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
systemctl | grep nvidia
sys-bus-pci-drivers-nvidia.device loaded active plugged /sys/bus/pci/drivers/nvidia
nvidia-persistenced.service loaded active running NVIDIA Persistence Daemon
