Hello. I am on a Metabox Alpha-V V158PNK, with NVIDIA RTX 3050Ti. I have had several issues with a fresh install of Ubuntu 22.04 (dual-boot with Windows 11).
I am able to boot when using nvidia-driver-525 (NOT nvidia-driver-525-open, then I have to use recovery mode), and was able to get the following output of nvidia-smi:
$ nvidia-smi
Fri Dec 30 16:12:00 2022
| NVIDIA-SMI 525.60.11 Driver Version: 525.60.11 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 38C P3 N/A / N/A | 5MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1982 G /usr/lib/xorg/Xorg 4MiB |
However, I cannot connect to any external monitor (I have a working HDMI cable), and on suspend the computer is unable to resume. xrandr shows HDMI-1 as disconnected.
I have tried various things with no success. hdmi and suspend/sleep works fine when in Windows, just not in ubuntu. I appreciate any advice you may have.
nvidia-bug-report.log: https://pastebin.com/YRxr7yNg
