I’m wondering why I cannot add articulation in my customized robot imported from Onshape.com?
Have you looked inside the Physics submenu at [Context menu] > Add > Physics?
Also, a tip for creating articulations according to the documentation: Articulations must have a tree structure in terms of the rigid-body links and the joints between them
If it doesn’t work, can you share the .usd for inspection?
Hello Toni. Thanks for your reply. I attached the usd file in the zip file.
It seems to be your robot has already the Articulation Root…
However, the joint drives are not defined.
You can add drives as follow:
I recommend you check the Rigging Robots tutorial (particularly Add Joints, Drives, and Articulations section) for adding and configuring joint drives.
Also, check this post for hints:
Thanks for your detailed reply! I really like it!
