Steps to reproduce:
- Open script editor in Isaac Sim 2022.2.0
- Paste and execute the following script
with rep.new_layer():
camera = rep.create.camera(position=(10, 10, 5), look_at=(0, 0, 0))
sphere_light = rep.create.light(
light_type="Sphere",
position=(10, 10, 20),
intensity=20000,
scale=10,
count=1
torus = rep.create.torus(semantics=[('class', 'torus')] ,
position=(0, 0 , 4),
rotation=(10, 20, 30))
with torus:
rep.physics.collider()
Output:
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] /Replicator/SDGPipeline/OgnSampleChoice: Assertion raised in compute - Tried to set a value on AttributeData '__resolved_outputs:samples' of type 'token' with incompatible data (Unable to cast Python instance to C++ type (compile in debug mode for details))
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] File "c:\users\brunovetter\appdata\local\ov\pkg\isaac_sim-2022.2.0\extscache\omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\ogn\python\_impl\nodes\OgnSampleChoice.py", line 115, in compute
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] db.outputs.samples = samples
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] File "c:\users\brunovetter\appdata\local\ov\pkg\isaac_sim-2022.2.0\extscache\omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\ogn\OgnSampleChoiceDatabase.py", line 168, in __setattr__
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] super().__setattr__(item, new_value)
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] File "c:\users\brunovetter\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\exts\omni.graph\omni\graph\core\_impl\database.py", line 657, in __setattr__
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] File "c:\users\brunovetter\appdata\local\ov\pkg\isaac_sim-2022.2.0\extscache\omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\ogn\OgnSampleChoiceDatabase.py", line 143, in samples
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] self.samples.value = value_to_set
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] File "c:\users\brunovetter\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\exts\omni.graph\omni\graph\core\_impl\utils.py", line 385, in wrapper_non_const
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] return func(self, *args, **kwargs)
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] File "c:\users\brunovetter\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\exts\omni.graph\omni\graph\core\_impl\runtime.py", line 126, in value
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] self.helper.set(new_value, on_gpu=self._on_gpu)
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] File "c:\users\brunovetter\appdata\local\ov\pkg\isaac_sim-2022.2.0\kit\exts\omni.graph\omni\graph\core\_impl\attribute_values.py", line 115, in set
2023-04-04 08:58:15 [Error] [omni.graph.core.plugin] self._data.set(new_value, on_gpu=on_gpu)
2023-04-04 08:58:15 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/SphereLight_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
2023-04-04 08:58:15 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Camera_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
2023-04-04 08:58:15 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Torus_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
2023-04-04 08:58:15 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Torus_Xform.xformOp:rotateXYZ is overridden in a stronger layer (Root Layer).
2023-04-04 08:58:15 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/SphereLight_Xform.xformOp:scale is overridden in a stronger layer (Root Layer).
2023-04-04 08:58:15 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Camera_Xform.xformOp:rotateXYZ is overridden in a stronger layer (Root Layer).
Any help welcome
Bruno
