Cannot create WFDDevice when using openwfd_nvsci_sample
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Currently, I connect my Drive Orin target device with a monitor DP cable and I tried to use the openwfd_nvsci_sample, but i got the error of initializing the OpenWFD immediately.
$ ./openwfd_nvsci_sample --sample 1 --display 0 --mode 1920x1080@60
Failed to create WFDDevice
Failed to initialize OpenWFD
Dear @rlu1 ,
Could you share syslog. Also,Could you check disconnecting monitor and use VNC and test application if it works?
That is what happen when I start the WFD sample
Apr 23 09:10:21 tegra-ubuntu openwfd_nvsci_sample: [20984256562] Module_id 83 Severity 5 : NvKms Backend initialization successful.Number of heads discovered:  1
Apr 23 09:10:21 tegra-ubuntu openwfd_nvsci_sample: [20984260346] Module_id 83 Severity 5 : head 0, number of windows 2. Window Ids - 0 1
Apr 23 09:10:21 tegra-ubuntu openwfd_nvsci_sample: [20984260947] Module_id 83 Severity 2 : NvKms Backend failed to acquire required permissions.
