Cannot debug application using WSL2 and cuda-gdb
I have a Windows machine where I wanted to use cuda-gdb within WSL2 using VS Code. When I launch my application, I am greeted with this:
WARNING: Debug interface is not enabled. Please see https://docs.nvidia.com/cuda/cuda-gdb/index.html#supported-platforms for more details.
I checked the linked webpage, and can confirm that the registry key exists with the required value.
$ Get-ItemProperty -Path "HKLM:\SOFTWARE\NVIDIA Corporation\GPUDebugger" -Name "EnableInterface" -ErrorAction SilentlyContinue | Select-Object EnableInterface
EnableInterface
              1
In fact, this was set by default and I didn’t have to modify anything. Additionally, here is what I get for running nvidia-smi within WSL:
Sun Dec 14 10:14:25 2025
| NVIDIA-SMI 580.102                Driver Version: 581.60         CUDA Version: 13.0     |
|   0  NVIDIA RTX A1000 6GB Lap...    On  |   00000000:01:00.0  On |                  N/A |
| N/A   36C    P8              6W /   72W |    1902MiB /   6144MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A          101781      C   /Utkarsh                              N/A      |
and this is the Linux kernel I am using:
6.6.87.2-microsoft-standard-WSL2
I could not find any fixes in the documentation online and other sources. The closest I could find was this post, but it still seems unresolved.
Cuda-gdb can’t step into kernel code in WSL2 - CUDA Developer Tools / CUDA-GDB - NVIDIA Developer Forums
Please let me know if anything else is required to be able to use cuda-gdb with the setup I have.
Thanks and regards,
Utkarsh
Hi, @utkarsh.verma
Sorry for the issue you met.
  1. Are you using Win10 or Win11 ?
  2. Can you please update wsl by “$wsl --update”?
  3. Can you please get latest R590 driver ? We have some fixes there.
Hi @veraj,
Thanks for getting back. Here are my answers to your questions:
  1. Windows 11 (update to date)
  2. I have updated WSL version 2.6.2.0
  3. Installed the new 591.44 NVIDIA driver.
After doing 2 and 3 (don’t know which one), it started working. Thanks!
Great to know it works !
Hi @veraj,
