Hey, I’ve just installed cuda 3.0 in ubuntu 9.10 x86_64. The host is able to see all devices and is able to run the SDK examples on every device, it compiled successfully and just to check I reran the make command to the ~/NVIDIA/C/common directory. This ubuntu 9.10 cuda 3.0 is in dual boot with a ubuntu 9.04 x86_64 cuda 2.3, that can run all my projects. However, on cuda 3.0 the output to make my projects is always:
/usr/bin/ld: cannot find -lcutil
collect2: ld returned 1 exit status
The environment variables PATH and LD_LIBRARY_PATH in either cuda are the same:
PATH= /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/cuda/bin
LD_LIBRARY_PATH= /usr/local/cuda/lib64:/home/user/NVIDIA_SDK/C/common/lib
and I’ve added to /etc/ld.so.conf
Can someone help me out and tell me what is wrong and needs be changed? Thank you.
