Fedora10
CUDA 2.2
I just “make” the deviceQuery Example in SDK,
With gcc 4.3.2, I got this:
[root@localhost deviceQuery]# make
/usr/bin/ld: cannot find -lcutil
collect2: ld return 1
make: *** […/…/bin/linux/release/deviceQuery] error 1
where is the -lcutil? How can I get it?
By the way, some information related:
[root@localhost mycuda]# echo $LD_LIBRARY_PATH
/usr/local/cuda/lib:
[root@localhost mycuda]# echo $PATH
/usr/bin:/usr/kerberos/sbin:/usr/local/cuda/bin:/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/ROLY/bin
[root@localhost deviceQuery]# find / | grep lcutil
///////////////That is, no such library?
libcutil is distributed in the SDK. You need run at least run make in the NVIDIA_GPU_Computing_SDK/C/common directory first to built the library.
