I have read a ton of posts but nothing helps. I cannot get my second monitor working.
Ubuntu 20.04,
Dell 5810,
(2) P-5000 GPUs,
Driver Version: 515.48.07
What is odd is when I go into settings, I cannot ‘join’ the displays. Settings ‘sees’ bot monitors but won’t let me join them. There are no blacklist files that I can find.
Here is a bug report.
nvidia-bug-report.log.gz (631.4 KB)
If anyone has any ideas I would love to hear them. This is a fresh install of 20.04 today. The only way pay a purple screen was to unplug the second monitor. The monitors are each plugged into a card.
Thanks,
Doug
Please make sure
sudo cat /sys/module/nvidia_drm/parameters/modeset
returns ‘N’, then use only this minimal xorg.conf:
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "Quadro P5000"
BusID "PCI:179:0:0"
Option "BaseMosaic" "true"
EndSection
Thanks for the tips. Unfortunately they did not help. I decided that I may have mucked with enough stuff that reloading the OS was in order. Unfortunately, or fortunately, I grabbed Ubuntu 22.04. I am stuck at a gray-black screen when the system boots. I have a mouse pointer but nothing else. I can get to a console.
I have change the /etc/default/grub file and remoded splash and quiet and added nomodeset and then ran update-grub. That did not change anything. I also created a blacklist-nvidia-nouveau.conf in /etc/modprobe.d. To this file I added two lines
blacklist nouveau
options nouveau modeset=0
and then ran update-initramfs -u and rebooted. No change. I can do a nvidia-smi and get a response so some thing is installed.
If you have any ideas I would be very appreciative.
Thanks,
Doug
Please create a new nvidia-bug-report.log.
Apologies. I neglected to include a bug report.
nvidia-bug-report.log.gz (559.9 KB)
This morning after sending you the bug report, I disconnected the second monitor and now the desktop is available on the first monitor.
Should I remove the nomodeset from the grub defaults and rebuild grub and see what happens?
Which version of the Driver should I be using? 515?
Should I plug both monitors into the same card or is it OK to have a monitor plugged into each card?
I apologize for the questions, but now that a little progress has been made I would like to get the second monitor working as well then document how I got here in case I have to reload my system.
I tried up upload another bug report from after I unplugged one monitor but it takes forever so I gave up.
Thanks,
Doug
