I am trying to install nvidia driver with RTX 2080 Ti in Ubuntu 18.04 LTS
After Installing nvidia-driver (version 418.56) , the system will not boot . The following output comes and the screen stays blinking :
/dev/sda4: recovering journal
/dev/sda4: clean, some numbers / some numbers file, some numbers / some numbers blocks
Output of following commands are :
lspci |grep -i nvidia
65:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti Rev. A] (rev a1)
65:00.1 Audio device: NVIDIA Corporation TU102 High Definition Audio Controller (rev a1)
65:00.2 USB controller: NVIDIA Corporation TU102 USB 3.1 Controller (rev a1)
65:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU102 UCSI Controller (rev a1)
uname -m && cat /etc/*release
x86_64
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.2 LTS"
NAME="Ubuntu"
VERSION="18.04.2 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04.2 LTS"
VERSION_ID="18.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
gcc --version
gcc (Ubuntu 7.3.0-27ubuntu1~18.04) 7.3.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
uname -r
4.18.0-15-generic
I tried installing Nvidia driver through two different following methods :
Using PPA :
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo ubuntu-drivers autoinstall
sudo apt install nvidia-418
Also through Nvidia site directly :
downloaded the display driver for Linux from
https://www.nvidia.com/download/driverResults.aspx/138279/en-us
chmod +x NVIDIA-Linux-x86_64–410.57.run
sudo ./NVIDIA-Linux-x86_64–410.57.run --no-x-check
In both cases the result is same and the system would not boot and gets stuck at the error mentioned before .
