Nvidia driver not working in Ubuntu 16.04 for Titan RTX Founder's edition
Getting black screen all the time after booting. Tried installing different version of the driver using command line.
Error:
2798.872365] systemd-logind[74296]: Failed to enable subscription: Launch helper exited with unknown return code 1
[ 2798.875363] systemd-logind[74296]: Failed to fully start up daemon: Input/output error
[ 2798.986109] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c4000-0x000c7fff window]
[ 2798.986253] caller os_map_kernel_space.part.8+0x6d/0x80 [nvidia] mapping multiple BARs
[ 2802.910581] NVRM: GPU 0000:65:00.0: RmInitAdapter failed! (0x24:0x65:1097)
[ 2802.910608] NVRM: GPU 0000:65:00.0: rm_init_adapter failed, device minor number 0
[ 2803.152200] upstart: lightdm main process (74288) terminated with status 1
[ 2803.152217] upstart: lightdm respawning too fast, stopped
[ 2805.146320] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c4000-0x000c7fff window]
[ 2805.146446] caller os_map_kernel_space.part.8+0x6d/0x80 [nvidia] mapping multiple BARs
[ 2809.070678] NVRM: GPU 0000:65:00.0: RmInitAdapter failed! (0x24:0x65:1097)
[ 2809.070707] NVRM: GPU 0000:65:00.0: rm_init_adapter failed, device minor number 0
[ 2819.986945] upstart: failsafe-x main process (74314) terminated with status 1
Please find the attached log for more info.
Notes:
  1. Using unsigned kernel version to install Nvidia driver
  2. Driver version tried: 430, 418, 415
nvidia-bug-report.log.gz (524 KB)
I’d say the 2080 is broken. Try reseating it, check in another system, then RMA.
