After solving the problem, described here
https://devtalk.nvidia.com/default/topic/1072554/cudnn/cannot-query-nvidia-drivers-on-ubuntu/post/5435138/#5435138
… the troubles related to the problem reappear.
Probably caused by update/upgrade, the request nvidia-smi doesn’t work anymore:
pavel@ALABAMA:~$ nvidia-smi
Failed to initialize NVML: Driver/library version mismatch
Any suggestions ?
The only solution that I’ve found is to reinstall CUDA.
So, 1st I de-installed CUDA using:
sudo apt-get --purge remove “nvidia”
Then I’ve tried to install once more using runfile approach from here:
https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=x86_64&target_distro=Ubuntu&target_version=1804&target_type=runfilelocal
Installation failed:
pavel@ALABAMA:~/Downloads$ sudo sh cuda_10.2.89_440.33.01_linux.run
[sudo] password for pavel:
Installation failed. See log at /var/log/cuda-installer.log for details.
pavel@ALABAMA:~/Downloads$ more /var/log/cuda-installer.log
[INFO]: Driver not installed.
[INFO]: Checking compiler version...
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)
[INFO]: Initializing menu
[INFO]: Setup complete
[INFO]: Initializing writeable menu
[INFO]: Components to install:
[INFO]: Driver
[INFO]: 440.33.01
[INFO]: Executing NVIDIA-Linux-x86_64-440.33.01.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-version-check --install-libglvnd 2>&1
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 440.33.01 failed, quitting
I reinstall CUDA.
Now it’s Ok:
Wed Mar 11 15:33:21 2020
| NVIDIA-SMI 440.33.01 Driver Version: 440.33.01 CUDA Version: 10.2 |
| 0 GeForce GTX 1050 On | 00000000:01:00.0 Off | N/A |
| N/A 44C P3 N/A / N/A | 209MiB / 2002MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1028 G /usr/lib/xorg/Xorg 115MiB |
| 0 1313 G /usr/bin/gnome-shell 93MiB |
Sorry for late reply.
That’s great, thanks a lot for updating the forum.
