Currently using connectx6 cards and trying to install the drivers on ubuntu 20.04. Successfully did this on two other identical systems already. On this system, the driver install completes successfully, but when I try to run sudo /etc/init.d/openibd restart I get the following error:
Unloading ib_core [FAILED]
rmmod: ERROR: Module ib_core is in use
I then run sudo lsmod | grep ib_core to find which modules are dependent on it and get the following output
ib_core 348160 2
mlx_compat 65536 1 ib_core
after attempting to run sudo modprobe -r mlx_compat I get the error
modprobe: FATAL: Module mlx_compat is in use.
I then run sudo lsmod | grep mlx_compat and get
It seems that ib_core and mlx_compat are dependent on each other. Even if I try to us rmmod -f I still am never able to unload either module. Because I can’t restart openibd, I am not able to see the network interfaces either. I did add the recommended blacklists and regenerated my initramfs as well. Any advice what to try next?
