Hi Sir/Madam,
I can import modulus after modulus bare metal installation. However, I cannot run the example since the permission to the hydra config file is denied. Any suggestions? Thanks.
Hi Sir/Madam,
Hi @dehao.liu12
We have not seen this error before. This is a permissions issue, so there is likely not much we can debug from our end.
Right now I would suggest first trying to run the intro hydra tutorial. If this does not work, I would consider opening a ticket on the Hydra github repo to ask about a solution.
I think you don’t have the permission. Please put the output of ls -la
in your directory.
The problem has been resolved.
Thanks for the help.
