I am using:
- Windows 10 Education
- Nsight 5.5 for Visual Studio
- Visual Studio 2017 Enterprise, version 15.5.6
- nVidia GeForce GTX 1050 Ti
- driver 391.01 installed
- glfw 3.2.1 windows pre-compiled downloaded from glfw website.
- gl3w just downloaded and built a days ago.
I have read the documentation on Graphics Debugger > Shader Debugging > OpenGL. I don’t have VS2015. It is my first use of Nsight. I read a thread in this forum here:https://devtalk.nvidia.com/default/topic/1026057/nsight-visual-studio-edition/can-t-insert-breakpoint/, but it offers me no help.
The program is build in VS2017 with Debug mode and x64 architecture. The program runs correctly in VS2017 without Nsight and in Frame Debugging mode within Nsight.
The screenshot for Shader tab:
I clicked the link for vertex shader in the above Shader tab, the source popped up, then I tried to set the breakpoint at the line “gl_Position = vPosition;” in the source tab, but failed.
The source is the first one in the Red Book “OpenGL Programming Guide: The Official Guide to Learning OpenGL, Version 4.5 with SPIR-V (9th Edition)” with some small irrelevant modifications. It is attached below (does this forum support file attachment?). Other parts of the source can be downloaded from the associated website of the book: http://www.opengl-redbook.com/
So, why can’t I set breakpoint? Did I not add necessary debugging information into GLSL(how to do that?)? How to solve this issue? Thanks a lot.
Sources:
(1) 01-triangles.cpp
// Triangles.cpp
#include <cstdlib>
#include <cstdio>
#include <iostream>
using namespace std;
#include <glm/fwd.hpp>
//#define GLM_FORCE_SWIZZLE
#include <glm/glm.hpp>
#include <glm/gtc/matrix_transform.hpp>
#include <glm/gtc/type_ptr.hpp>
//#include <glad/glad.h>
#include "vgl.h"
#include "LoadShaders.h"
enum VAO_IDs { Triangles, NumVAOs };
enum Buffer_IDs { ArrayBuffer, NumBuffers };
enum Attrib_IDs { vPosition = 0 };
GLuint VAOs[NumVAOs];
GLuint Buffers[NumBuffers];
const GLuint NumVertices = 6;
void glm_test() {
glm::vec4 vec(1.0f, 0.0f, 0.0f, 1.0f);
// glm::vec3 swizzle = vec.xzy;
glm::mat4 trans;
trans = glm::translate(trans, glm::vec3(1.0f, 1.0f, 0.0f));
vec = trans * vec;
std::cout << vec.x << vec.y << vec.z << std::endl;
// init
void
init( void )
GLfloat vertices[NumVertices][2] = {
{ -0.90f, -0.90f },{ 0.85f, -0.90f },{ -0.90f, 0.85f }, // Triangle 1
{ 0.90f, -0.85f },{ 0.90f, 0.90f },{ -0.85f, 0.90f } // Triangle 2
glGenVertexArrays(NumVAOs, VAOs);
glBindVertexArray(VAOs[Triangles]);
//glGenBuffers(NumBuffers, Buffers);
glCreateBuffers(NumBuffers, Buffers);
glBindBuffer(GL_ARRAY_BUFFER, Buffers[ArrayBuffer]);
//glBufferData(GL_ARRAY_BUFFER, sizeof(vertices), vertices, GL_STATIC_DRAW);
glBufferStorage(GL_ARRAY_BUFFER, sizeof(vertices), vertices, 0);
glCreateVertexArrays(NumVAOs, VAOs);
glNamedBufferStorage(Buffers[ArrayBuffer], sizeof(vertices), vertices, 0);
glVertexAttribPointer(vPosition, 2, GL_FLOAT, GL_FALSE, 0, BUFFER_OFFSET(0));
glEnableVertexAttribArray(vPosition);
ShaderInfo shaders[] = {
{ GL_VERTEX_SHADER, "E:\\path\\to\\the\\vertex\\shader\\triangles.vert" },
{ GL_FRAGMENT_SHADER, "E:\\path\\to\\the\\frag\\shader\\triangles.frag" },
{ GL_NONE, NULL }
GLuint program = LoadShaders(shaders);
glUseProgram(program);
glm_test();
// display
void
display( void )
static const float black[] = { 0.2f, 0.2f, 0.2f, 1.0f };
glClearBufferfv(GL_COLOR, 0, black);
//glBindVertexArray( VAOs[Triangles] );
glDrawArrays( GL_TRIANGLES, 0, NumVertices );
void error_callback(int error, const char* description)
fprintf(stderr, "Error: %s\n", description);
// main
int
main( int argc, char** argv )
glfwSetErrorCallback(error_callback);
int major, minor, rev;
glfwGetVersion(&major, &minor, &rev);
printf("%s\n", glfwGetVersionString());
if (!glfwInit())
exit(EXIT_FAILURE);
glfwWindowHint(GLFW_CONTEXT_VERSION_MAJOR, 4);
glfwWindowHint(GLFW_CONTEXT_VERSION_MINOR, 5);
glfwWindowHint(GLFW_OPENGL_PROFILE, GLFW_OPENGL_CORE_PROFILE);
GLFWwindow* window = glfwCreateWindow(800, 600, "Triangles", NULL, NULL);
glfwMakeContextCurrent(window);
gl3wInit();
if (gl3wIsSupported(4, 5));
glViewport(150, 100, 600, 400);
int fbw, fbh;
glfwGetFramebufferSize(window, &fbw, &fbh);
init();
int nrAttributes;
glGetIntegerv(GL_MAX_VERTEX_ATTRIBS, &nrAttributes);
std::cout << "Maximum # of vertex attributes supported: " << nrAttributes << std::endl;
while (!glfwWindowShouldClose(window))
display();
glfwSwapBuffers(window);
//glfwPollEvents();
glfwWaitEvents();
glfwDestroyWindow(window);
glfwTerminate();
(2) triangles.vert
#version 450 core
layout( location = 0 ) in vec4 vPosition;
void
main()
(3)triangles.frag
#version 450 core
out vec4 fColor;
void main()
fColor = vec4(0.5, 0.4, 0.8, 1.0);
