project type is “Make Application (ndk-build → .apk)”
Hovering over the breakpoint display a tooltip:
“The breakpoint will not currently be hit. The module containing the breakpoint location is not loaded” External Image
Despite the message above, my library is loaded.
The modules window in VS show the library (libtest472.so) as loaded.
Breakpoints work OK if using
the 4.7 toolchain (instead of 4.7.5)
project type “Application (.so → .apk)” instead of “Make Application (ndk-build → .apk)”;
My Android.mk is:
LOCAL_PATH := $(subst //,/,$(call my-dir))
include $(CLEAR_VARS)
LOCAL_MODULE := test472
LOCAL_SRC_FILES := HelloJni.c
include $(BUILD_SHARED_LIBRARY)
hi EiH_x,
when will you encounter this issue? Normally, this is just tips when you set a Breakpoint to a line that would be able to hit during the next debug running.
for example, you set a BP in native code, while your debug mode is Java code.
Currently, we do not provide support for modifying user’s .mk files. Almost all makefile-related things must be done manually. On the other hand, if the user has a MSBuild-based project, Nsight Tegra will do the great amount of work for them.
As for the bug reporting - we monitor the forums regularly and create the tickets as issues are mentioned here.
