Cannot set up Raspberyy pi HQ camera with CSI
Im using Jetson orin Nano 8gb with waveshare board. I’m using the Raspberyy pi hq camera which uses Sony IMX477R camera in it. I’ve already set up both of my csi ports(cam0 and cam1) to use the 477 pin layout using jetson-io.py.
Despite my attempts, I couldnt get it to work. Here is how the camera is connected:
here’s the output when I run simple_camera.py from CSI-Camera repository by JetsonHacks.
nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)30/1 ! nvvidconv flip-method=0 ! video/x-raw, width=(int)960, height=(int)540, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 1
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
[ WARN:0@4.334] global cap_gstreamer.cpp:1728 open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
False
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
  File "/home/user/CSI-Camera/simple_camera.py", line 76, in <module>
    show_camera()
  File "/home/user/CSI-Camera/simple_camera.py", line 61, in show_camera
    cv2.imshow(window_title, frame)
cv2.error: OpenCV(4.8.0) /home/ubuntu/opencv_build/opencv/modules/highgui/src/window.cpp:971: error: (-215:Assertion failed) size.width>0 && size.height>0 in function 'imshow'
Hello @starwinguav,
Can you try with:
gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! ximagesink
Please let us now if you require further assistance.
regards,
Andrew
support@proventusnova.com
Also checking if any i2c error in the dmesg.
And try another camera port.
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 No cameras available
Redistribute latency...
WARNING: from element /GstPipeline:pipeline0/GstXImageSink:ximagesink0: Pipeline construction is invalid, please add queues.
Additional debug info:
../libs/gst/base/gstbasesink.c(1249): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstXImageSink:ximagesink0:
Not enough buffering available for  the processing deadline of 0:00:00.015000000, add enough queues to buffer  0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element "pipeline0".
Execution ended after 0:00:00.012116320
Setting pipeline to NULL ...
Freeing pipeline ...
doesnt work
log.txt (55.1 KB)
here’s the dmesg log. There seems to be a i2c error during i2c read probe.
[    0.227165] i2c_dev: i2c /dev entries driver
[    4.151977] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    4.155336] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    4.157631] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    4.159821] tegra-i2c c240000.i2c: Adding to iommu group 1
[    4.161965] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    4.162593] tegra-i2c c250000.i2c: Adding to iommu group 1
[    4.166128] i2c i2c-2: Added multiplexed i2c bus 9
[    4.166730] i2c i2c-2: Added multiplexed i2c bus 10
[    4.166740] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
[   14.823819] imx477 9-001a: imx477_board_setup: error during i2c read probe (-121)
[   15.126832] imx477 10-001a: imx477_board_setup: error during i2c read probe (-121)
does the pin layout differ for the imx477R ? I also tried setting the pin layout as imx477 dual but doesnt work sadly
I tried using the cam0 port and now I get a black screen when I run gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! ximagesink
   Camera index = 0
   Camera mode  = 1
   seconds to Run    = 0
(Argus) Error FileOperationFailed: Failed socket read: Connection reset by peer (in src/rpc/socket/common/SocketUtils.cpp, function readSocket(), line 79)
(Argus) Error FileOperationFailed: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error FileOperationFailed: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 339)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 355)
(Argus) Error FileOperationFailed: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error FileOperationFailed: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error FileOperationFailed:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Execution ended after 0:00:04.013048430
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Caught SIGSEGV
Segmentation fault (core dumped)```
the simple_camera.py seems to give a different error:
   Camera index = 0
   Camera mode  = 1
   seconds to Run    = 0
[ WARN:0@6.621] global cap_gstreamer.cpp:2784 handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module nvarguscamerasrc0 reported: DISCONNECTED
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
cam.sh: line 2:  5848 Segmentation fault      (core dumped) python3 simple_camera.py
here’s the dmesg log:
log.txt (55.2 KB)
It works now, I had to set the 24 pin CSI layout to IMX 477 dual 4 lane and use the cam1 port
