Hello Experts!
I couldn’t setup Jetpack 4.2.2 Rev1 on a 32 GB San Disk SD card in the Jetson Nano Developer Kit. I am using the SDK Manager and the flashing process finishes ok, but it only uses the first 14 GB of the card and then there are 13 weird partitions.
I get the message ‘Resizing the SD card failed’ during bootup. The recommended
systemctl status nvresizefs.service says:
● nvresizefs.service - Resize SD Card root partition and filesystem
Loaded: loaded (/etc/systemd/system/nvresizefs.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2019-09-24 15:41:33 CEST; 2min 25s ago
Main PID: 15857 (code=exited, status=4)
Sep 24 15:41:33 jet nvresizefs.sh[15857]: The operation has completed successfully.
Sep 24 15:41:33 jet nvresizefs.sh[15857]: Could not create partition 1 from 40 to 62333912
Sep 24 15:41:33 jet nvresizefs.sh[15857]: Setting name!
Sep 24 15:41:33 jet nvresizefs.sh[15857]: partNum is 0
Sep 24 15:41:33 jet nvresizefs.sh[15857]: Unable to set partition 1's name to 'APP'!
Sep 24 15:41:33 jet nvresizefs.sh[15857]: Could not change partition 1's type code to EBD0A0A2-B9E5-4433-87C0-68B6B72699C7!
Sep 24 15:41:33 jet nvresizefs.sh[15857]: Error encountered; not saving changes.
Sep 24 15:41:33 jet systemd[1]: nvresizefs.service: Main process exited, code=exited, status=4/NOPERMISSION
Sep 24 15:41:33 jet systemd[1]: nvresizefs.service: Failed with result 'exit-code'.
Sep 24 15:41:33 jet systemd[1]: Failed to start Resize SD Card root partition and filesystem.
What am I doing wrong?
Thomas
