Cannot use replicator camera in RL environment at version 2023.1.1
When I try to get the point cloud data, I have a problem using cameras with replicator at version 2023.1.1.
The file torch_ur5e_reaching_target_pcd_ppo.py from the below attachment works well on Isaac Sim 2023.1.0-hotfix.1, but not on Isaac Sim 2023.1.1. (You can check with unzip the file below at the same level of omniisaacgymenvs at OmniIsaacGymEnvs)
ur5e_reaching_target_pcd_ppo.zip (12.5 MB)
reaching_target_pcd_log.txt (34.0 KB)
The camera did not create well after creating the scene. Especially, the log said as the text below.
2024-02-26 05:16:09 [10,308ms] [Error] [omni.kit.app._impl] [py stderr]: /home/bak/.local/share/ov/pkg/isaac_sim-2023.1.1/extscache/omni.replicator.core-1.10.20+105.1.lx64.r.cp310/omni/replicator/core/ogn/python/_impl/nodes/OgnSampleUniform.py:56: UserWarning: Expected inputs:num_samples to be greater than 0 but instead received 0
  warnings.warn(f"Expected inputs:num_samples to be greater than 0 but instead received {num_samples}")
2024-02-26 05:16:10 [10,811ms] [Warning] [omni.hydra.scene_delegate.plugin] Calling getBypassRenderSkelMeshProcessing for prim /World/envs/env_0/robot/wrist_3_link/visuals.proto_mesh_0_id0 that has not been populated
2024-02-26 05:16:10 [10,904ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name='Task-416' coro=<Writer.__attach_async() done, defined at /home/bak/.local/share/ov/pkg/isaac_sim-2023.1.1/extscache/omni.replicator.core-1.10.20+105.1.lx64.r.cp310/omni/replicator/core/scripts/writers.py:418> exception=ValueError('Unable to get camera path from omni.replicator.core.create.camera')>
  File "/home/bak/.local/share/ov/pkg/isaac_sim-2023.1.1/extscache/omni.replicator.core-1.10.20+105.1.lx64.r.cp310/omni/replicator/core/scripts/writers.py", line 422, in __attach_async
    render_products_results = [rp.result() if asyncio.isfuture(rp) else rp for rp in render_products]
  File "/home/bak/.local/share/ov/pkg/isaac_sim-2023.1.1/extscache/omni.replicator.core-1.10.20+105.1.lx64.r.cp310/omni/replicator/core/scripts/writers.py", line 422, in <listcomp>
  File "/home/bak/.local/share/ov/pkg/isaac_sim-2023.1.1/extscache/omni.replicator.core-1.10.20+105.1.lx64.r.cp310/omni/replicator/core/scripts/create.py", line 1363, in get_camera_paths_async
    raise ValueError(f"Unable to get camera path from {camera}")
ValueError: Unable to get camera path from omni.replicator.core.create.camera
When it works well on the hotfix version, the camera path is created automatically. I tried to input a specific camera path on self.rep.create.camera at the 2023.1.1 but it did not work.
I think there is a problem with replicator and omnigraph related modules using the arguments. I checked the difference between the hotfix version and 2023.1.1 with debug mode and, they are not the same when creating camera instances. (I cannot understand about deeper inside structure.)
Is there any solution to this???
Has anyone tried getting point cloud at RL environments?
