I think that a joint can not set to the articulation root.
In this post, the articulation root is set to the root link.
Is /firefighter/base already set to the articulation root?
| Failed to query Articulation in python script | 10 | 177 | October 28, 2025 | |
| Moving Articulation Root | 2 | 750 | May 17, 2024 | |
| URDF Importer unable to add Articulation Root | 5 | 261 | January 8, 2025 | |
| How to fix the root body of a robot in Isaac Sim? | 15 | 3771 | April 5, 2024 | |
| URDF importer probloms with setting articulation root | 2 | 258 | December 15, 2024 | |
| Adding a new robot by using URDF importer (Invalid Articulation handle) | 1 | 462 | April 19, 2024 | |
| Struggling with articulations and articulation inspector in tutorial 5.7 | 3 | 633 | March 11, 2024 | |
| How to change articulation root by python code script | 4 | 327 | July 12, 2024 | |
| Omnigraph Articulation Velocity Controller won't let me use the articulation root | 2 | 334 | July 31, 2024 | |
| Unable to add articulation to a custom biped robot | 1 | 137 | January 7, 2025 |
