I tried to boot jetson nano from flashing microsd image via etcher in windows. The image is jetpack 6.0. When trying to boot it just gets stuck on the screen above.
Can anyone help me fix this?
Thanks in advance
Joe
I have exactly the same issue- Jetson Orin Nano doesn't boot after updated to 5.0 (JetPack 5.1.3)
The advice is to flash the Jetson device with SDK Manager. Somehow it doesn’t work for me as the “Flash” button never gets active when I choose “Manual mode”.
You are trying to boot the JetPack 6 image on a machine with JetPack 5 firmware (the UEFI firmware is 5.0-x as shown in the top line). The firmware is stored in QSPI memory. The following procedure will walk you through the process of updating the firmware using the SD card method:
🚅 Initial Setup Guide - Jeton Orin Nano 🆕 - NVIDIA Jetson AI Lab
Here’s a video documenting the procedure:
Hope this helps
Yea i tried jetpack 5.13 also and got this error when trying to flash via micro sd via etcher. Tried sdk but instillation keeps failing.
Thanks man i’ll try this with jetpack 6 and see if it works
Kind regards
Joe
It worked, thanks a lot for this man.
Saved me a lot of time
Kind regards
Joe
