I’m reopening the discussion from Xavier NX boot failure
Now that I managed to set up the serial console I got the output below.
jetson_output.txt (24.5 KB)
This error message looks particularly concerning to me:
[0011.221] E> Error 892665857: Failed to read CVM EEPROM
Is that a hardware problem?
Best,
Julio
hello juliostorch,
here’re errors about EEPROM reading failures.
[0001.509] I> Reading eeprom i2c=1 address=0x50
[0001.511] E> I2C: slave not found in slaves.
[0001.511] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.512] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.513] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.521] E> eeprom: Retry to read I2C slave device.
[0001.526] E> I2C: slave not found in slaves.
[0001.530] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.538] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.543] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.553] E> eeprom: Failed to read I2C slave device
[0001.558] I> Eeprom read failed 0x3526070d
did you reproduce this with Xavier NX devkit? or you’re having board customization?
thanks
Hi Jerry,
I reproduced it with a Xavier NX devkit.
Hi Jerry,
Is this fixable or should I request an RMA?
hello juliostorch,
please contact the NVIDIA Customer Care team for RMA process.
thanks
