I tried using an sd card with a fresh image and also flashing from the SDK manager with the board in recovery mode, both methods I’ve used before, but it didn’t work. I got the same error when booting from the fresh image, and flashing failed with the SDK manager.
I also tried flashing with the command line script contained in the image downloaded by the SDK manager and it failed with “CPU Bootloader is not running on device”. flash_fail.txt (5.2 KB)
Is there anything else I can do to solve the issue or is the board defective?
I tried JetPack 4.4 and 4.4.1. I’m using ubuntu 18.04 without VM, the same pc/OS I used before to flash the board without a problem.
may I know what’s the modification you’d done, had you overwrite bootloader binaries?
please share the flash commands you’re using, you may also have an alternative way by specify board information for flashing.
thanks
it switch the rootfs to a NVMe SSD,
please using the exactly same JetPack release (i.e. JetPack 4.4-DP) as GitHub mentioned since we don’t verify it locally.
thanks
I did try with the same JetPack release. In any case, when I replace the SD card with a new image it won’t try to boot from the SSD anymore. I managed to recover from a problem in the SSD by replacing the SD card before, but that doesn’t work anymore.
hello juliostorch,
please setup serial console to gather the details bootloader logs for reference,
thanks
