I was trying to connect Pixhawk Cube to Jetson Nano via UART
I connected pins 8 and 10 to RX and Tx of Pixhawk(Telem2) respectively also connected the ground
But on doing “ls /dev” in the terminal, there were no new ports displayed when I connected everything.
also when I did “systemctl --type=service --state=failed” in the terminal it showed “nvgetty service :uart on ttyTHS0 failed”
what should i do so as to connect ??
Welcome to the forums! This topic belongs in the Jetson category. I am going to move it over for you so the team has visibility.
Hi arjun222gupta,
Are you using the devkit or custom board for Jetson Nano?
May I know what’s your use case for this?
Could you help to provide the serial console log when you are doing this for further check?
