• Hardware Platform (Jetson / GPU): Jetson Orin Nano
• DeepStream Version: 7.1
• JetPack Version (valid for Jetson only): 6.2.1 (L4T 36.4.4)
• TensorRT Version: 10.3.0.30
• NVIDIA GPU Driver Version (valid for GPU only): 540.4.0
• Issue Type( questions, new requirements, bugs): bugs
I’m working with the face detection with 2 version MobileNet and Resnet Retinaface with DeepStream. I’ve successfully implemented with deepstream-app:
deepstream_retinaface.txt (2.1 KB)
config_infer_retinaface.txt (676 Bytes)
custom_parser_retinaface.cpp:
// To make the custom parser file to make it works with 2 versions of Retinaface,
// two version of the generate_priors function had been implemented, also the image size need to be changed belong to the engine. Other code had kept unchanged.
#include <iostream>
#include <vector>
#include <cmath>
#include <algorithm>
#include <cstring>
#include <array>
#include "nvdsinfer_custom_impl.h"
#define NUM_LANDMARKS 5
#define LANDMARK_STRIDE 10 // 5 points -> 10 values
// RetinaFace prior settings
static const std::vector<std::vector<int>> MIN_SIZES = {
{16, 32},
{64, 128},
{256, 512}
static const std::vector<int> STEPS = {8, 16, 32};
static const int IMAGE_SIZE = 840;
// // Generate priors (for 640x640 input)
// static bool generate_priors(std::vector<std::array<float,4>> &priors)
// priors.clear();
// for (size_t s = 0; s < STEPS.size(); s++) {
// int step = STEPS[s];
// int feature_h = std::ceil(IMAGE_SIZE / step);
// int feature_w = std::ceil(IMAGE_SIZE / step);
// for (int i = 0; i < feature_h; i++) {
// for (int j = 0; j < feature_w; j++) {
// for (size_t k = 0; k < MIN_SIZES[s].size(); k++) {
// int min_size = MIN_SIZES[s][k];
// float cx = (j + 0.5f) * step / IMAGE_SIZE;
// float cy = (i + 0.5f) * step / IMAGE_SIZE;
// float w = (float)min_size / IMAGE_SIZE;
// float h = (float)min_size / IMAGE_SIZE;
// priors.push_back({cx, cy, w, h});
// return true;
// // Generate priors (for 840x840 input)
priors.clear();
// CRITICAL: Calculate feature map size exactly as Python math.ceil()
// Integer division in C++ rounds down. We need ceil.
int feature_h = (IMAGE_SIZE + step - 1) / step;
int feature_w = (IMAGE_SIZE + step - 1) / step;
// Center coordinates
// Width and Height relative to image size
return true;
// Decode bbox
static void decode_boxes(
const float *bbox,
const std::vector<std::array<float,4>> &priors,
std::vector<std::array<float,4>> &out)
out.resize(priors.size());
for (size_t i = 0; i < priors.size(); i++) {
float cx = priors[i][0];
float cy = priors[i][1];
float w = priors[i][2];
float h = priors[i][3];
float dx = bbox[i*4 + 0] * 0.1f;
float dy = bbox[i*4 + 1] * 0.1f;
float dw = bbox[i*4 + 2] * 0.2f;
float dh = bbox[i*4 + 3] * 0.2f;
float pred_cx = dx * w + cx;
float pred_cy = dy * h + cy;
float pred_w = std::exp(dw) * w;
float pred_h = std::exp(dh) * h;
float x1 = pred_cx - pred_w / 2.f;
float y1 = pred_cy - pred_h / 2.f;
float x2 = pred_cx + pred_w / 2.f;
float y2 = pred_cy + pred_h / 2.f;
out[i] = {x1, y1, x2, y2};
// Decode 5-point landmarks
static void decode_landmarks(
const float *landm,
std::vector<std::array<float,10>> &out)
std::array<float,10> pts{};
for (int p = 0; p < NUM_LANDMARKS; p++) {
float lx = landm[i*LANDMARK_STRIDE + p*2 + 0] * 0.1f * w + cx;
float ly = landm[i*LANDMARK_STRIDE + p*2 + 1] * 0.1f * h + cy;
pts[p*2 + 0] = lx;
pts[p*2 + 1] = ly;
out[i] = pts;
// NMS
static void do_nms(
const std::vector<std::array<float,5>> &dets,
float thresh,
std::vector<int> &keep)
keep.clear();
if (dets.empty()) return;
std::vector<int> order(dets.size());
for (size_t i = 0; i < dets.size(); i++) order[i] = (int)i;
// sort by score desc
std::sort(order.begin(), order.end(),
[&](int a, int b){ return dets[a][4] > dets[b][4]; });
std::vector<bool> removed(dets.size(), false);
for (size_t _i = 0; _i < order.size(); _i++) {
int i = order[_i];
if (removed[i]) continue;
keep.push_back(i);
float x1 = dets[i][0];
float y1 = dets[i][1];
float x2 = dets[i][2];
float y2 = dets[i][3];
float area_i = (x2 - x1) * (y2 - y1);
for (size_t _j = _i + 1; _j < order.size(); _j++) {
int j = order[_j];
if (removed[j]) continue;
float xx1 = std::max(x1, dets[j][0]);
float yy1 = std::max(y1, dets[j][1]);
float xx2 = std::min(x2, dets[j][2]);
float yy2 = std::min(y2, dets[j][3]);
float w = std::max(0.0f, xx2 - xx1);
float h = std::max(0.0f, yy2 - yy1);
float inter = w * h;
float area_j = (dets[j][2] - dets[j][0]) * (dets[j][3] - dets[j][1]);
float ovr = inter / (area_i + area_j - inter);
if (ovr >= thresh)
removed[j] = true;
// Parser entry
extern "C" bool NvDsInferParseCustomRetinaFace(
const std::vector<NvDsInferLayerInfo> &layersInfo,
const NvDsInferNetworkInfo &networkInfo,
const NvDsInferParseDetectionParams &detectionParams,
std::vector<NvDsInferObjectDetectionInfo> &objects)
const float *loc_data = nullptr;
const float *conf_data = nullptr;
const float *landm_data = nullptr;
for (auto &layer : layersInfo) {
if (strcmp(layer.layerName, "bbox") == 0)
loc_data = (float*)layer.buffer;
else if (strcmp(layer.layerName, "confidence") == 0)
conf_data = (float*)layer.buffer;
else if (strcmp(layer.layerName, "landmark") == 0)
landm_data = (float*)layer.buffer;
if (!loc_data || !conf_data || !landm_data) {
std::cerr << "Missing RetinaFace output tensors!" << std::endl;
return false;
// 1. Generate priors
std::vector<std::array<float,4>> priors;
generate_priors(priors);
int num_priors = priors.size();
// 2. Decode boxes
std::vector<std::array<float,4>> boxes;
decode_boxes(loc_data, priors, boxes);
// 3. Decode landmarks
std::vector<std::array<float,10>> landms;
decode_landmarks(landm_data, priors, landms);
// 4. Filter + collect raw detections
std::vector<std::array<float,5>> dets;
for (int i = 0; i < num_priors; i++) {
float score = conf_data[i*2 + 1];
if (score < detectionParams.perClassThreshold[0])
continue;
float x1 = boxes[i][0] * networkInfo.width;
float y1 = boxes[i][1] * networkInfo.height;
float x2 = boxes[i][2] * networkInfo.width;
float y2 = boxes[i][3] * networkInfo.height;
dets.push_back({x1, y1, x2, y2, score});
// 5. NMS
float nms_thresh = 0.5f;
if (detectionParams.perClassPostclusterThreshold.size() > 0) {
float t = detectionParams.perClassPostclusterThreshold[0];
if (t > 0.0f && t < 1.0f) nms_thresh = t;
std::vector<int> keep;
do_nms(dets, nms_thresh, keep);
// 6. Output objects
for (int idx : keep) {
NvDsInferObjectDetectionInfo obj;
obj.classId = 0;
obj.detectionConfidence = dets[idx][4];
obj.left = dets[idx][0];
obj.top = dets[idx][1];
obj.width = dets[idx][2] - dets[idx][0];
obj.height = dets[idx][3] - dets[idx][1];
objects.push_back(obj);
return true;
extern "C" bool NvDsInferInitialize()
std::cout << "Custom RetinaFace parser initialized!" << std::endl;
return true;
extern "C" void NvDsInferDeInitialize()
But I need to implement face recognition later so I decided to change to DeepStream / GStreamer Python, I keep the custom parser and model-level config file “config_infer_retinaface.txt”, use the Python file as the pipeline-level config file. The problem happens now: I’m trying to write the output file without hardware encoder because we don’t have it in Jetson Orin Nano right? But I can’t do it.
To be specific, let’s me give the code. At first, I tried this code, the program can run without any bug in log, but the window is keep freezing and the output video file is nothing.
import sys
import gi
gi.require_version("Gst", "1.0")
gi.require_version("GstVideo", "1.0")
from gi.repository import Gst, GLib
# Initialize GStreamer
Gst.init(None)
# USER CONFIG
VIDEO_PATH = "/home/ubuntu/projects/faceRecognizer-main/demoVideos/unknown/demo_video_3.mp4"
OUTPUT_PATH = "out_retinaface.mp4" # Use "" to disable saving file
DISPLAY = True
MODEL_CONFIG_PATH = "./config_infer_retinaface.txt"
MUXER_WIDTH = 1920
MUXER_HEIGHT = 1080
BATCH_PUSH_TIMEOUT = 33333 # 1/ SOURCE_FPS * 1000 * 1000 (microseconds)
# BUS CALLBACK
def bus_call(bus, message, loop):
msg_type = message.type
if msg_type == Gst.MessageType.EOS:
print("End of stream")
loop.quit()
elif msg_type == Gst.MessageType.ERROR:
err, debug = message.parse_error()
print(f"Error: {err} — {debug}")
loop.quit()
return True
# MAIN PIPELINE
def main():
loop = GLib.MainLoop()
pipeline = Gst.Pipeline.new("ds-retinaface-pipeline")
# Source
source = Gst.ElementFactory.make("filesrc", "file-source")
source.set_property("location", VIDEO_PATH)
# Demux
demux = Gst.ElementFactory.make("qtdemux", "demuxer")
# Parser + decoder
parser = Gst.ElementFactory.make("h264parse", "h264-parser")
decoder = Gst.ElementFactory.make("nvv4l2decoder", "video-decoder")
# Streammux
streammux = Gst.ElementFactory.make("nvstreammux", "streammux")
streammux.set_property("width", MUXER_WIDTH)
streammux.set_property("height", MUXER_HEIGHT)
streammux.set_property("batch-size", 1)
streammux.set_property("batched-push-timeout", BATCH_PUSH_TIMEOUT)
# PGIE (RetinaFace)
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
pgie.set_property("config-file-path", MODEL_CONFIG_PATH)
pgie.set_property("gpu-id", 0)
# Converter + OSD
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "nvvideo-converter")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreen-display")
# Add all to pipeline
for elem in [source, demux, parser, decoder, streammux, pgie, nvvidconv, nvosd]:
pipeline.add(elem)
# Connect demux dynamically
def on_pad_added(demux, pad):
pad_caps = pad.query_caps(None).to_string()
if "video" in pad_caps:
pad.link(parser.get_static_pad("sink"))
demux.connect("pad-added", on_pad_added)
# Link fixed components
source.link(demux)
parser.link(decoder)
# decoder -> streammux
sinkpad = streammux.get_request_pad("sink_0")
decoder_srcpad = decoder.get_static_pad("src")
decoder_srcpad.link(sinkpad)
# Inference pipeline
streammux.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(nvosd)
# SINK SETUP
if DISPLAY and OUTPUT_PATH:
# Tee
tee = Gst.ElementFactory.make("tee", "tee")
q1 = Gst.ElementFactory.make("queue", "q-display")
q2 = Gst.ElementFactory.make("queue", "q-file")
# Display sink
sink_display = Gst.ElementFactory.make("nveglglessink", "display")
sink_display.set_property("sync", 0)
# File sink (CPU Encoder setup)
videoconv_cpu = Gst.ElementFactory.make("videoconvert", "videoconv-cpu") # Chuyển NVMM -> CPU
encoder_cpu = Gst.ElementFactory.make("x264enc", "encoder-cpu") # CPU Encoder
encoder_cpu.set_property("bitrate", 4000000)
encoder_cpu.set_property("speed-preset", 1)
muxer = Gst.ElementFactory.make("qtmux", "muxer")
sink_file = Gst.ElementFactory.make("filesink", "file-sink")
sink_file.set_property("location", OUTPUT_PATH)
pipeline.add(tee)
pipeline.add(q1)
pipeline.add(q2)
pipeline.add(sink_display)
pipeline.add(videoconv_cpu) # THÊM
pipeline.add(encoder_cpu) # THAY THẾ nvv4l2h264enc
pipeline.add(muxer)
pipeline.add(sink_file)
nvosd.link(tee)
# branch 1: display
tee.link(q1)
q1.link(sink_display)
# branch 2: save file
tee.link(q2)
q2.link(videoconv_cpu)
videoconv_cpu.link(encoder_cpu)
encoder_cpu.link(muxer)
muxer.link(sink_file)
elif DISPLAY:
nvosd.link(sink_display)
elif OUTPUT_PATH:
pipeline.add(muxer)
nvosd.link(videoconv_cpu)
# BUS
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
# Run
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
pipeline.set_state(Gst.State.NULL)
if __name__ == "__main__":
main()
Then I tried this code, in general, sometimes it runs the whole video, displays and records the video well, sometimes it runs smoothly and suddenly stops halfway, the display window closes, the recorded video also has an error, cannot be opened, also there are some bugs in log that I will give below:
import sys
import gi
import os
import signal
from gi.repository import Gst, GLib, GObject
# Optional: import pyds if you want to use DeepStream metadata functions later.
try:
import pyds
except Exception:
pyds = None
Gst.init(None)
# ---------------- USER CONFIG ----------------
# MODEL_CONFIG_PATH must include parse-bbox-func-name + custom-lib-path if you're using your C++ parser.
MODEL_CONFIG_PATH = "/home/ubuntu/retinaface_deepstream/config_infer_retinaface.txt"
# Output file (leave "" to disable saving)
OUTPUT_PATH = "/home/ubuntu/projects/faceRecognizer-main/out_retinaface_python.mp4"
# Display toggle
DISPLAY = True
# Streammux settings (choose what you used in your pipeline-level config)
MUXER_WIDTH = 552 # use your desired streammux width
MUXER_HEIGHT = 1080
BATCH_SIZE = 1
BATCH_PUSH_TIMEOUT = 33000 # in ms (matches your earlier config)
# GPU id
GPU_ID = 0
t = message.type
if t == Gst.MessageType.EOS:
print("End-of-stream")
loop.quit()
elif t == Gst.MessageType.ERROR:
print("Error from element %s: %s" % (message.src.get_name(), err))
print("Debug info: %s" % debug)
loop.quit()
return True
def create_element(factoryname, name=None, required=True):
el = Gst.ElementFactory.make(factoryname, name)
if required and el is None:
raise RuntimeError(f"Could not create element {factoryname} ({name})")
return el
def main():
# Build pipeline
pipeline = Gst.Pipeline.new("ds-retinaface-pipeline-py")
if not pipeline:
print("Unable to create pipeline")
return 1
# Source + demux + parse + decode
source = create_element("filesrc", "file-source")
demux = create_element("qtdemux", "demuxer")
h264parse = create_element("h264parse", "h264-parser")
decoder = create_element("nvv4l2decoder", "nvv4l2-decoder")
# Streammux (collect frames into batch for inference)
streammux = create_element("nvstreammux", "stream-muxer")
streammux.set_property("batch-size", BATCH_SIZE)
streammux.set_property("live-source", False)
# Primary inference (RetinaFace) - using your model-level config with custom parser
pgie = create_element("nvinfer", "primary-inference")
pgie.set_property("gpu-id", GPU_ID)
# Convert + OSD (NVMM pipeline for display)
nvvidconv_post = create_element("nvvideoconvert", "nvvidconv-post")
nvosd = create_element("nvdsosd", "nv-onscreendisplay")
# Elements for display branch
sink_display = None
if DISPLAY:
sink_display = create_element("nveglglessink", "nv-display")
sink_display.set_property("sync", False)
# Elements for file save branch (software encode path)
# We will force NVMM -> System memory before x264enc:
# nvosd (NVMM) -> queue -> nvvidconv -> capsfilter(video/x-raw, format=I420, memory:System) -> queue -> x264enc -> qtmux -> filesink
encoder = None
muxer = None
sink_file = None
if OUTPUT_PATH:
# Use nvvidconv to do format conversion and memory:System
nvvidconv_to_cpu = create_element("nvvideoconvert", "nvvidconv-to-cpu")
# capsfilter to ensure I420 and System memory
caps = Gst.Caps.from_string("video/x-raw, format=I420, width=%d, height=%d, memory:System" % (MUXER_WIDTH, MUXER_HEIGHT))
capsfilter = create_element("capsfilter", "capsfilter-to-cpu")
capsfilter.set_property("caps", caps)
# Make a queue before software encoder to isolate thread pools
queue_encode = create_element("queue", "queue-encode")
# Use x264enc (software) — configure properties as you need (bitrate, tune, speed-preset...)
encoder = create_element("x264enc", "x264-encoder")
# tune zero-latency and speed options may help
encoder.set_property("bitrate", 4000) # kbps
encoder.set_property("speed-preset", "ultrafast")
encoder.set_property("tune", "zerolatency")
# Optionally parse h264 stream (not always required)
h264parse_out = create_element("h264parse", "h264parse-out")
# Container muxer
muxer = create_element("qtmux", "qtmux")
sink_file = create_element("filesink", "file-sink")
# Add elements to pipeline
elems = [source, demux, h264parse, decoder, streammux, pgie, nvvidconv_post, nvosd]
if DISPLAY:
elems.append(sink_display)
if OUTPUT_PATH:
elems += [nvvidconv_to_cpu, capsfilter, queue_encode, encoder, h264parse_out, muxer, sink_file]
for e in elems:
pipeline.add(e)
# Link source->demux dynamically
def demux_pad_added(demux, pad):
s = caps.to_string()
if "video" in s:
sink_pad = h264parse.get_static_pad("sink")
if not pad.is_linked() and sink_pad and not sink_pad.is_linked():
pad.link(sink_pad)
demux.connect("pad-added", demux_pad_added)
# static links:
source.link(demux)
h264parse.link(decoder)
# decoder -> streammux (request sink pad)
if not sinkpad:
raise RuntimeError("Unable to get streammux sink_0 pad")
if not srcpad:
raise RuntimeError("Unable to get decoder src pad")
ret = srcpad.link(sinkpad)
if ret != Gst.PadLinkReturn.OK:
raise RuntimeError("Failed to link decoder src to streammux sink_0")
# streammux -> pgie -> nvvidconv_post -> nvosd
pgie.link(nvvidconv_post)
nvvidconv_post.link(nvosd)
# create tee after nvosd
if DISPLAY or OUTPUT_PATH:
tee = create_element("tee", "tee-postosd")
pipeline.add(tee)
nvosd.link(tee)
# Branch 1: display (NVMM path)
if DISPLAY:
queue_disp = create_element("queue", "queue-display")
pipeline.add(queue_disp)
tee.link(queue_disp)
queue_disp.link(sink_display)
# Branch 2: file encode (convert to CPU memory then software encode)
if OUTPUT_PATH:
queue_enc_in = create_element("queue", "queue-enc-in")
pipeline.add(queue_enc_in)
tee.link(queue_enc_in)
# Link branch: queue_enc_in -> nvvidconv_to_cpu -> capsfilter -> queue_encode -> encoder -> h264parse_out -> muxer -> filesink
queue_enc_in.link(nvvidconv_to_cpu)
nvvidconv_to_cpu.link(capsfilter)
capsfilter.link(queue_encode)
queue_encode.link(encoder)
# Some x264enc versions output bytestream requiring h264parse
encoder.link(h264parse_out)
h264parse_out.link(muxer)
# Bus / messages
# Handle SIGINT gracefully
def sigint_handler(sig, frame):
print("SIGINT received: stopping pipeline")
pipeline.send_event(Gst.Event.new_eos())
signal.signal(signal.SIGINT, sigint_handler)
# Start
print("Starting pipeline...")
try:
loop.run()
except Exception as e:
print("Exception in main loop:", e)
finally:
print("Pipeline stopped, cleaned up.")
return 0
sys.exit(main())
Bug 1:
(venv) ubuntu@tegra-ubuntu:~/projects/deepstream-python$ python3 deepstream-face_detection.py
/home/ubuntu/projects/deepstream-python/deepstream-face_detection.py:159: DeprecationWarning: Gst.Element.get_request_pad is deprecated
Using winsys: x11
Opening in BLOCKING MODE
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
0:00:00.327408789 86244 0xaaaaef57d130 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/home/ubuntu/models/engine/retinaface_engine/FaceDetector_MobileNet_Dynamic_640_b32.engine
INFO: [FullDims Engine Info]: layers num: 4
0 INPUT kFLOAT input 3x640x640 min: 1x3x640x640 opt: 32x3x640x640 Max: 32x3x640x640
1 OUTPUT kFLOAT bbox 16800x4 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT confidence 16800x2 min: 0 opt: 0 Max: 0
3 OUTPUT kFLOAT landmark 16800x10 min: 0 opt: 0 Max: 0
0:00:00.327677821 86244 0xaaaaef57d130 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /home/ubuntu/models/engine/retinaface_engine/FaceDetector_MobileNet_Dynamic_640_b32.engine
0:00:00.352690201 86244 0xaaaaef57d130 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:/home/ubuntu/projects/deepstream-python/config_infer_retinaface.txt sucessfully
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
0:00:11.403036272 86244 0xaaaaeec98060 WARN nvinfer gstnvinfer.cpp:2423:gst_nvinfer_output_loop:<primary-inference> error: Internal data stream error.
0:00:11.403092689 86244 0xaaaaeec98060 WARN nvinfer gstnvinfer.cpp:2423:gst_nvinfer_output_loop:<primary-inference> error: streaming stopped, reason error (-5)
Error from element primary-inference: gst-stream-error-quark: Internal data stream error. (1)
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2423): gst_nvinfer_output_loop (): /GstPipeline:ds-retinaface-pipeline-py/GstNvInfer:primary-inference:
nvstreammux: Successfully handled EOS for source_id=0
(python3:86244): GStreamer-CRITICAL **: 14:57:24.512: gst_mini_object_unref: assertion '(g_atomic_int_get (&mini_object->lockstate) & LOCK_MASK) < 4' failed
Bug 2:
(venv) ubuntu@tegra-ubuntu:~/projects/deepstream-python$ gst_debug=5 python3 deepstream-face_detection.py
Using winsys: x11
0:00:00.303223457 107768 0xaaab0c1b3330 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/home/ubuntu/models/engine/retinaface_engine/FaceDetector_MobileNet_Dynamic_640_b32.engine
0:00:00.303377669 107768 0xaaab0c1b3330 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /home/ubuntu/models/engine/retinaface_engine/FaceDetector_MobileNet_Dynamic_640_b32.engine
0:00:00.329360490 107768 0xaaab0c1b3330 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:/home/ubuntu/retinaface_deepstream/config_infer_retinaface.txt sucessfully
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform_copy.cpp:438: => Failed in mem copy
0:01:00.022592279 107768 0xaaab0d72b700 ERROR nvinfer gstnvinfer.cpp:1267:get_converted_buffer:<primary-inference> cudaMemset2DAsync failed with error cudaErrorIllegalAddress while converting buffer
0:01:00.022648985 107768 0xaaab0d72b700 WARN nvinfer gstnvinfer.cpp:1576:gst_nvinfer_process_full_frame:<primary-inference> error: Buffer conversion failed
Error from element primary-inference: gst-stream-error-quark: Buffer conversion failed (1)
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1576): gst_nvinfer_process_full_frame (): /GstPipeline:ds-retinaface-pipeline-py/GstNvInfer:primary-inference
0:01:00.056651745 107768 0xaaab0d72b700 ERROR nvinfer gstnvinfer.cpp:1267:get_converted_buffer:<primary-inference> cudaMemset2DAsync failed with error cudaErrorIllegalAddress while converting buffer
0:01:00.056708899 107768 0xaaab0d72b700 WARN nvinfer gstnvinfer.cpp:1576:gst_nvinfer_process_full_frame:<primary-inference> error: Buffer conversion failed
0:01:00.056814854 107768 0xaaab0d72b700 ERROR nvinfer gstnvinfer.cpp:1267:get_converted_buffer:<primary-inference> cudaMemset2DAsync failed with error cudaErrorIllegalAddress while converting buffer
0:01:00.056843303 107768 0xaaab0d72b700 WARN nvinfer gstnvinfer.cpp:1576:gst_nvinfer_process_full_frame:<primary-inference> error: Buffer conversion failed
CUDA Runtime error cudaFreeHost(host_) # an illegal memory access was encountered, code = cudaErrorIllegalAddress [ 700 ] in file /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/memory.hpp:78
CUDA Runtime error cudaFree(device_) # an illegal memory access was encountered, code = cudaErrorIllegalAddress [ 700 ] in file /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/memory.hpp:79
(venv) ubuntu@tegra-ubuntu:~/projects/deepstream-python$ GST_DEBUG=3 python3 deepstream-face_detection.py
0:00:00.115030181 127722 0xaaaabfb2d2f0 WARN structure gststructure.c:2250:gst_structure_parse_field: missing assignment operator in the field, str=memory:System
0:00:00.115088678 127722 0xaaaabfb2d2f0 WARN structure gststructure.c:2350:priv_gst_structure_parse_fields: Failed to parse field, r=memory:System
Using winsys: x11
0:00:00.213501112 127722 0xaaaabfb2d2f0 WARN v4l2 gstv4l2object.c:4682:gst_v4l2_object_probe_caps:<nvv4l2-decoder:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.215119362 127722 0xaaaabf616980 WARN aggregator gstaggregator.c:2099:gst_aggregator_query_latency_unlocked:<qtmux> Latency query failed
0:00:00.291660279 127722 0xaaaabfb2d2f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/home/ubuntu/models/engine/retinaface_engine/FaceDetector_MobileNet_Dynamic_640_b32.engine
0:00:00.291784762 127722 0xaaaabfb2d2f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /home/ubuntu/models/engine/retinaface_engine/FaceDetector_MobileNet_Dynamic_640_b32.engine
0:00:00.316514370 127722 0xaaaabfb2d2f0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:/home/ubuntu/retinaface_deepstream/config_infer_retinaface.txt sucessfully
0:00:00.317081233 127722 0xaaaabfb2d2f0 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete:<file-source> pad not activated yet
0:00:00.317655616 127722 0xaaaabfb656a0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:00.317683361 127722 0xaaaabfb656a0 WARN qtdemux qtdemux_types.c:249:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:00.317750467 127722 0xaaaabfb656a0 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex:<demuxer> failed to find fragment defaults for stream 1
0:00:00.317906279 127722 0xaaaabfb656a0 WARN qtdemux qtdemux.c:3121:qtdemux_parse_trex:<demuxer> failed to find fragment defaults for stream 2
0:00:00.429077255 127722 0xaaaabfb656a0 WARN v4l2 gstv4l2object.c:4682:gst_v4l2_object_probe_caps:<nvv4l2-decoder:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.435811895 127722 0xaaaabfb656a0 WARN v4l2videodec gstv4l2videodec.c:2297:gst_v4l2_video_dec_decide_allocation:<nvv4l2-decoder> Duration invalid, not setting latency
0:00:00.464161566 127722 0xaaaabfb656a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1130:gst_v4l2_buffer_pool_start:<nvv4l2-decoder:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.493687683 127722 0xaaaac19c1b60 WARN v4l2bufferpool gstv4l2bufferpool.c:1607:gst_v4l2_buffer_pool_dqbuf:<nvv4l2-decoder:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:00.584235239 127722 0xaaaabf616980 FIXME basesink gstbasesink.c:3395:gst_base_sink_default_event:<file-sink> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:00.634210852 127722 0xaaaabf616980 FIXME aggregator gstaggregator.c:1410:gst_aggregator_aggregate_func:<qtmux> Subclass should call gst_aggregator_selected_samples() from its aggregate implementation.
0:00:06.941681687 127722 0xaaaabf616920 ERROR egladaption gstegladaptation.c:363:got_gl_error: GL ERROR: glEGLImageTargetTexture2DOES returned 0x0502
0:00:06.941823643 127722 0xaaaabf616920 ERROR nveglglessink gsteglglessink.c:2154:gst_eglglessink_upload:<nv-display> Failed to upload texture
0:00:06.944127063 127722 0xaaaabfb65460 WARN nvinfer gstnvinfer.cpp:2423:gst_nvinfer_output_loop:<primary-inference> error: Internal data stream error.
0:00:06.944175545 127722 0xaaaabfb65460 WARN nvinfer gstnvinfer.cpp:2423:gst_nvinfer_output_loop:<primary-inference> error: streaming stopped, reason error (-5)
0:00:06.955896748 127722 0xaaaabfb656a0 WARN qtdemux qtdemux.c:6760:gst_qtdemux_loop:<demuxer> error: Internal data stream error.
0:00:06.956044624 127722 0xaaaabfb656a0 WARN qtdemux qtdemux.c:6760:gst_qtdemux_loop:<demuxer> error: streaming stopped, reason error (-5)
(python3:127722): GStreamer-CRITICAL **: 16:13:40.947: gst_mini_object_unref: assertion '(g_atomic_int_get (&mini_object->lockstate) & LOCK_MASK) < 4' failed
(venv) ubuntu@tegra-ubuntu:~/projects/deepstream-python$ GST_DEBUG=:nvinfer:3 python3 deepstream-face_detection.py
Using winsys: x11
0:00:00.308702580 129138 0xaaaaff42e930 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/home/ubuntu/models/engine/retinaface_engine/FaceDetector_MobileNet_Dynamic_640_b32.engine
0:00:00.308832632 129138 0xaaaaff42e930 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /home/ubuntu/models/engine/retinaface_engine/FaceDetector_MobileNet_Dynamic_640_b32.engine
0:00:00.333184098 129138 0xaaaaff42e930 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:/home/ubuntu/retinaface_deepstream/config_infer_retinaface.txt sucessfully
[cuOSD Error] at /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/cuda/cuosd_kernel.cu:1072 : Launch kernel (render_elements_kernel) failed, code = 700CUDA Runtime error cudaPeekAtLastError() # an illegal memory access was encountered, code = cudaErrorIllegalAddress [ 700 ] in file /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/cuosd.cpp:968
0:00:30.014167083 129138 0xaaab009a6b00 ERROR nvinfer gstnvinfer.cpp:1267:get_converted_buffer:<primary-inference> cudaMemset2DAsync failed with error cudaErrorIllegalAddress while converting buffer
0:00:30.014432722 129138 0xaaab009a6b00 WARN nvinfer gstnvinfer.cpp:1576:gst_nvinfer_process_full_frame:<primary-inference> error: Buffer conversion failed
ERROR: Failed to make stream wait on event, cuda err_no:700, err_str:cudaErrorIllegalAddress
ERROR: Preprocessor transform input data failed., nvinfer error:NVDSINFER_CUDA_ERROR
0:00:30.020030248 129138 0xaaaafeb4a0c0 WARN nvinfer gstnvinfer.cpp:1420:gst_nvinfer_input_queue_loop:<primary-inference> error: Failed to queue input batch for inferencing
Unable to set device in gst_nvstreammux_src_collect_buffers
