can't find download of cuda-gdb
I want to debug my program with cuda gdb (console / gui) but I can’t find the cuda gdb no where…
not in my PC and not on the internet. where can I find it?
cuda-gdb is installed with the cuda toolkit. Only on linux.
If you have the cuda toolkit installed on linux, and you have done a proper install, you simply need to type:
cuda-gdb
at a command prompt.
Proper install:
especially see section 7.
im on windows
cuda-gdb is not available for use on windows.
For windows debugging, the recommended tool is the debugger built into Nsight Visual Studio Edition.
refer to slide 4 here:
http://developer.download.nvidia.com/GTC/PDF/1062_Satoor.pdf
I don’t use visual studio. I use visual studio code.
You can use whatever you wish of course. If you want to use a NVIDIA-supplied debugger on windows, it would be as I stated.
Visual studio code is not a supported environment (by NVIDIA) for CUDA development work.
