E: Package linux-headers-4.9.140-tegra cannot be found.
E: Using the pattern “linux-headers-4.9.140-tegra” no package could be found.
E: Using the regular expression “linux-headers-4.9.140-tegra” no package could be found.
ccd3@ccd3-desktop:~$ aket linux-headers-4.9.140-tegra could not be found
I searched for instructions to install the tegra kernel but did not find anything. Does anyone has a instruction or can tell me how to install the package?
I think the Linux kernel headers should be on your target Jetson system already. Check the path /usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aarch64.
The base rootfs should be all ready for target compilation. Have you tried skipping the apt-get for those two packages altogether?
thanks for your reply! In the meantime I changed my objective and now working on getting the same library up inside of an docker container. There I get another error I can’t find anything about on the internet (in a comparable use case). I creating another topic in this forum to not mixing up different topics. But maybe it is kind of related to each other?
