I use the MBF2H332A-AENOT DPU card purchased by the company.This card has been used by my colleague all along, and recently she told me that the network cannot establish a connection. Previously, it was used as a regular network interface card.
I received this card and installed the complete development environment on the host system, as well as the latest doca.
If failure is encountered, check “cat /dev/rshim0/misc”
If image successfully loaded, flash FW from DPU or from physical host follow by a cold boot
Should the issue persist & you have a supported BF2 Nvidia contract, open a support case and our team will further investigate/debug
Enterprise Support EnterpriseSupport@nvidia.com
emmmm
It seems like it cannot be modified.
I don’t really want to provide a purchase contract, because if I want to repair it, I need to use the return process to return this card to our warehouse, and then our procurement specialist will proceed to apply for repair. Only our procurement specialist knows about the purchase contract. This process is quite cumbersome and time-consuming. And I also want to know how to repair this card in this situation.
