Bluefield DPU2 bringup failied
Hi Folks,
i’m unable to upgarde the dpu bf image to latest.
I downloaded the image from Linux Installation Guide :: NVIDIA DOCA SDK Documentation .
root@UCSC-C240-M6S:/home/ubuntu# bfb-install --bfb DOCA_2.0.2_BSP_4.0.3_Ubuntu_22.04-10.23-04.prod.bfb --config bf.cfg --rshim rshim0
Pushing bfb + cfg
cat: write error: Connection timed out ]
320KiB 0:02:35 [2.06KiB/s] [ <=> ]
Failed to push BFB
Console log:
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/rshim0/console, 11:50:59
Press CTRL-A Z for help on special keys
Mellanox BlueField-2 A1 BL1 V1.1
ERROR: Failed to load BL2R firmware.
root@UCSC-C240-M6S:# lspci -s $(sudo lspci -d 15b3: | head -1 | awk ‘{print $1}’) -vvv | grep “Product Name”
Product Name: BlueField-2 P-Series DPU 100GbE Dual-Port QSFP56, integrated BMC, Secure Boot Enabled, Crypto Disabled, 16GB on-board DDR, 1GbE OOB management, FHHL
root@localhost:/home/ubuntu# bfrec
primary: /dev/mmcblk0boot0
backup: /dev/mmcblk0boot1
boot-bus-width: x8
reset to x1 after reboot: FALSE
watchdog-swap: disabled
lifecycle state: Secured (development)
secure boot key free slots: 3
What could be the issue?
Have you tried to disable secure boot, push 2.0.2 then re-enable secure boot?
