Can't flash Xavier NX due to not enough space on the APP partition
I’m using SDK Manager to flash JetPack 5.1.2 a Jetson Xavier NX, but it always crashes due to not enough space.
The APP partition is always set at 14 GB and I’m unable to make it larger. I’ve tried flashing in runtime mode, but the Ubuntu setup manager window doesn’t ask me to change the size. How can I move forward with this?
Here are the logs: SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Xavier_NX_modules_2023-10-20_12-18-39.zip (681.5 KB)
Same exact issue here
Hi @aurelien.montmejat , @amehrez,
This is what you should be checking:
