nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Fri May 2 16:32:25 2008
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : true
no ncurses color : false
query latest version : false
OpenGL header files : true
no questions : false
silent : false
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
no cc version check : false
force tls : (not specified)
X install prefix : (not specified)
X library install path : (not specified)
X module install path : (not specified)
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
doc install prefix : (not specified)
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : ftp://download.nvidia.com
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> The file '/tmp/.X0-lock' exists and appears to contain the process ID '6140'
of a runnning X server.
ERROR: You appear to be running an X server; please exit X before installing.
For further details, please see the section INSTALLING THE NVIDIA DRIVER
in the README available on the Linux driver download page at
www.nvidia.com.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at www.nvidia.com.
-> No precompiled kernel interface was found to match your kernel; would you li
 ke the installer to attempt to download a kernel interface for your kernel f
 rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
 this means that the installer will need to compile a kernel interface for
 your kernel.
ERROR: You do not appear to have libc header files installed on your system.
   Please install your distribution's libc development package.
EDIT:
I isntalled some modified driver and now all is OK solved :)
DaveBG
I have this problem also, when I try to install “NVIDIA-Linux-x86_64-180.06-pkg2.run” - “No precompiled kernel interface was found to match your kernel”. Can you tell me, where I can find this modified driver?
PS. I use Red Hat Enterprise Linux Server release 5.3
I can’t install CUDA driver on 9800GX2 under Red Hat Linux Enterprise Linux Server 5.3. Help me somebody please <img src=‘http://hqnveipbwb20/public/style_emoticons/<#EMO_DIR#>/crying.gif’ class=‘bbc_emoticon’ alt=‘:’(’ />
It is the libc development package. You can ask Redhat how to install that, I don’t know with which tools it is done in RHEL, but in Fedora Core I go to Applications → Add/Remove Software
[codebox]ERROR: Unable to load the kernel module ‘nvidia.ko’. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if a driver such as rivafb/nvidiafb is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA graphics device(s), or NVIDIA GPU installed in this system is not supported by this NVIDIA Linux graphics driver release.
Please see the log entries ‘Kernel module load error’ and ‘Kernel messages’ at the end of the file ‘/var/log/nvidia-installer.log’ for more information.[/codebox]
