If I change the transform matrix of an object with rep.modify.pose I can’t obtain it back. I tried with different methods. Here I post 3 examples.
Example 1
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp(
launch_config={"renderer": "RayTracedLighting", "headless": True}
import numpy as np
from omni.isaac.core.utils import prims
import omni.isaac.core.utils.prims as prims_utils
import omni.usd
cone = rep.create.cone(position=(0.0, 0.0, 0.0), rotation=(0.0, 0.0, 0.0))
with cone:
rep.modify.pose(
position=rep.distribution.uniform((-1.0, -1.0, -1.0), (-0.5, -0.5, -0.5)),
rotation=rep.distribution.uniform((90.0, 90.0, 90.0), (100.0, 100.0, 100.0)),
prim_path = rep.utils.get_node_targets(cone.node, "inputs:prims")[0]
prim = omni.usd.get_context().get_stage().GetPrimAtPath(str(prim_path))
transform_matrix = np.array(omni.usd.get_world_transform_matrix(prim)).T
print(transform_matrix)
translation = prims_utils.get_prim_property(prim_path, "xformOp:translate")
quaternion = prims_utils.get_prim_property(prim_path, "xformOp:rotateXYZ")
print(translation, quaternion)
simulation_app.close()
Example 2
import numpy as np
import omni.usd
prim_path = "/MyObjects/mycone"
prim = prims.create_prim(prim_path=prim_path, usd_path="/tmp/cone.usd")
cone = rep.get.prim_at_path(prim_path)
with cone:
rep.modify.pose(
quaternion = prims_utils.get_prim_property(prim_path, "xformOp:orient")
Example 3
import numpy as np
import omni.usd
The output of example 1 is:
[[1. 0. 0. 0.]
[0. 1. 0. 0.]
[0. 0. 1. 0.]
[0. 0. 0. 1.]]
(0, 0, 0) (0, 0, 0)
The output of example 2 is:
[[1. 0. 0. 0.]
[0. 1. 0. 0.]
[0. 0. 1. 0.]
[0. 0. 0. 1.]]
(0, 0, 0) (1, 0, 0, 0)
The output of example 3 is:
[[1. 0. 0. 0.]
[0. 1. 0. 0.]
[0. 0. 1. 0.]
[0. 0. 0. 1.]]
None None
The file I used:
cone.usd (30.8 KB)
But if I use a different method to set the transform matrix with a different method it works. I show a modifed version of the example 2:
import numpy as np
import omni.usd
import random
from pxr import Gf
my_transform_matrix = np.eye(4)
my_transform_matrix[0, 3] = random.uniform(-1.0, -0.5)
my_transform_matrix[1, 3] = random.uniform(-1.0, -0.5)
my_transform_matrix[2, 3] = random.uniform(-1.0, -0.5)
transform = Gf.Transform(Gf.Matrix4d(my_transform_matrix.T))
rotation = transform.GetRotation()
quaternion = rotation.GetQuat()
translation = transform.GetTranslation()
prims_utils.set_prim_property(prim_path, "xformOp:translate", translation)
prims_utils.set_prim_property(prim_path, "xformOp:orient", quaternion)
The output is:
[[ 1. 0. 0. -0.9777302 ]
[ 0. 1. 0. -0.92811792]
[ 0. 0. 1. -0.65131342]
[ 0. 0. 0. 1. ]]
(-0.9777302028157011, -0.9281179232026341, -0.6513134187091592) (1, 0, 0, 0)
