Hi, I have Jetson AGX Orin 32GB version and I have 500GB SSD driver installed on int but I cant successfully reflash.
I am using docker sdkmanager here is the command:
docker run -it --rm --privileged --network host \
-v /dev/bus/usb:/dev/bus/usb/ \
-v /dev:/dev \
-v $(pwd):/home/nvidia/Downloads/nvidia/sdkm_downloads \
-v /media/$USER:/media/nvidia:slave \
sdkmanager:1.9.3.10904-Ubuntu_20.04 \
--cli install \
--logintype devzone \
--product Jetson \
--version 5.1.2 \
--targetos Linux \
--host \
--target JETSON_AGX_ORIN_TARGETS \
--flash all \
--additionalsdk 'DeepStream 6.3' \
--downloadfolder /home/nvidia/Downloads/nvidia/sdkm_downloads \
--license accept \
--staylogin true \
--datacollection enable \
--exitonfinish
And I see this:
What is curious is that after few reboot it is power up and I see old system…
What am I doing wrong?
When in this process can I can oem-config?
EEPROM:
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 02 00 fe 00 00 00 00 00 00 00 00 00 00 00 00 00 ?.?.............
10: 00 00 00 0a 36 39 39 2d 31 33 37 30 31 2d 30 30 ...?699-13701-00
20: 30 30 2d 35 30 30 20 4d 2e 30 00 00 00 00 00 00 00-500 M.0......
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
40: 00 00 00 00 c8 15 a5 2d b0 48 31 34 32 33 36 32 ....???-?H142362
50: 32 30 32 37 30 38 37 00 00 00 00 00 00 00 00 00 2027087.........
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 00 00 00 00 00 00 4e 56 43 42 00 00 4d 31 00 00 ......NVCB..M1..
a0: 00 00 00 00 00 00 00 00 00 00 00 00 c8 15 a5 2d ............???-
b0: b0 48 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 ?H?.............
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 57 ...............W
I see in flash logs that there is errors but I am doing flashing from docker image.
Best regards,
Darek
