Phone is Xiaomi Mi 10 and it works perfectly on my personal computer so no USB cable problems. When I plug it in to TX2 and turn tethering ON 2 interfaces appear on ifconfig:
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b6:ae:6f:04:47:31 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b6:ae:6f:04:47:33 txqueuelen 1000 (Ethernet)
Output of lshw -C network:
*-network:0
description: Ethernet interface
physical id: 3
logical name: rndis0
serial: b6:ae:6f:04:47:31
capabilities: ethernet physical
configuration: broadcast=yes driver=g_ether driverversion=29-May-2008 firmware=tegra-xudc link=no multicast=yes
*-network:3
physical id: 6
logical name: usb0
serial: b6:ae:6f:04:47:33
configuration: broadcast=yes driver=g_ether driverversion=29-May-2008 firmware=tegra-xudc ip=192.168.42.111 link=no multicast=yes
As seen above it seems like the driver g_ether is being used but I think it should be using rndis_host since in my personal computer with Ubuntu Mate it works instantly by loading the rndis_host module. Besides that I can’t even find g_ether anywhere on the board.
I’ve tried to load rndis_host module with modprobe. It works but it is not used. Output of lsmod:
lsmod
Module Size Used by
rndis_host 10756 0
Output of modinfo rndis_host is:
modinfo rndis_host
filename: /lib/modules/4.9.140-tegra/kernel/drivers/net/usb/rndis_host.ko
license: GPL
description: USB Host side RNDIS driver
author: David Brownell
alias: usb:v*p*d*dc*dsc*dp*icE0isc01ip03in*
alias: usb:v*p*d*dc*dsc*dp*icEFisc01ip01in*
alias: usb:v*p*d*dc*dsc*dp*ic02isc02ipFFin*
alias: usb:v1630p0042d*dc*dsc*dp*ic02isc02ipFFin*
depends:
intree: Y
vermagic: 4.9.140-tegra SMP preempt mod_unload modversions aarch64
Output of usb-devices shows that the phone is detected but no driver is loaded:
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 21 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2717 ProdID=ff88 Rev=04.19
S: Manufacturer=Xiaomi
S: Product=Mi 10
S: SerialNumber=bb43e11
C: #Ifs= 3 Cfg#= 1 Atr=c0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=ef(misc ) Sub=04 Prot=01 Driver=(none)
I: If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=(none)
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=42 Prot=01 Driver=(none)
I have also run lsmod on my PC and found out this:
rndis_host 20480 0
cdc_ether 20480 1 rndis_host
usbnet 45056 2 rndis_host,cdc_ether
mii 20480 1 usbnet
So aparently there are this 3 other modules that I need but do not exist on my TX2. How can I make this work?
Thank you very much
