I have a sensor camera driver which supports capture from 2 cameras using the same CSI port and different virtual channel.
I’m using JetPack 4.4.
I have noticed the following strange behavior when capturing with nvarguscamerasrc:
- If start the capture for
sensor-id=1(which uses virtual-channel=1), capture works correct and I can stop and restart the streaming without issues. - Then, if I start the capture on
sensor-id=0, capture works correct and I can stop and restart the streaming without issues. - After stopping
sensor-id=0, If I try to capture again with withsensor-id=1, capture doesn’t work anymore.
When enabling the debug for nvargus-daemon, the error reported is because of no frames arrived after the timeout:
NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxGetCaptureStatus(), line 362)
I also ran the same test, but removing timeout restriction (enableCamInfiniteTimeout=1), I saw that no error appears during step 3, but no frames are captured. However, I verified that while capture was hanging for sensor-id=0, if capture was enabled for sensor-id=0`, I was able to capture images from both cameras.
So, basically the problem I have seen is that when sensor-id=0 capture is disabled, capture on sensor-id=1 will not work.
For v4l2 capture, this issue does not appear, however I noticed that if video1 is running and the streaming on video0 is started, the capture on video1 is interrupted for a second and these messages are observed on dmesg output:
[ 236.989243] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 236.989267] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
These issues don’t happens if I try to capture from 2 streams using different CSI ports.
I wonder if you have seen this issue before?
Thanks,
-Enrique
