Hi! I bout a Jetson Xavier Module from AVerMedia (Standard Box PC NX211B Equips NVIDIA® Jetson™ Xavier™ NX Module│AVerMedia). After many fails, i realize that form some reason when i flash from the original L4T image, the system not recognize the SD Card Reader. The SD card reader only works with the image from AVerMedia…
So i want to change of carrier board, what carrier do you recomend?
Requirement of the problem: 1 html, 2 usb and a compact form easy to install will be grate.
Thanks!!
