Compatibility Jetson Xavier NX with NX215 Carrier Board - AVerMedia
Hello.
I purchased an NX215 Carrier Board - AVerMedia and installed Jetson Xavier NX (180-13668-DAAA-02) into it.
As a result, the Jetson Xavier NX module failed. Could this be because I was using the Jetson Xavier NX from the Jetson NX Development Kit (Model P3518)?
Thank you.
English is not my native language, so please be kind to my mistakes.
You mean the Xavier NX can boot up with NX Development Kit(carrier board) successfully, but can’t boot up with NX215 Carrier Board, right?
Have you flashed with BSP for the NX215 Carrier Board?
You mean the Xavier NX can boot up with NX Development Kit(carrier board) successfully, but can’t boot up with NX215 Carrier Board, right? - yes.
Have you flashed with BSP for the NX215 Carrier Board? - yes.
I was able to find out the reason - maybe this information will be useful to someone.
Avermedia BSP doesn’t support the Xavier-NX dev-kit SoM
To use Xavier-NX with Avermedia, you must use a separately purchased Som.
Tested Avermedia with 900-83668-0030-000 - everything works successfully.
Thank you.
Gald to know you found the cause and resolved it. Thanks for the sharing!
