CGF- Unable to bind schedule_manager
Software Version
DRIVE OS 6.0.8.1
Target Operating System
Linux
Hardware Platform
Host Machine Version
Hi I am unable to understand cause of this error while i run a simple CGF sample.
launch script used :
/usr/local/driveworks/bin/launcher --binPath=/usr/local/driveworks/bin --spec=/home/CGFMultiplierSampleTest/app/sampleTest5.app.json --logPath=/home/CGFMultiplierSampleTest/logSpace --dwdatapath=/usr/local/driveworks/data --schedule=/home/CGFMultiplierSampleTest/scheduleFiles/sampleTest5__standardSchedule.stm --start_timestamp=0 --loglevel=DW_LOG_DEBUG --fullscreen=1 --winSizeW=1280 --winSizeH=800 --disableStmControlLogger=0 --gdb_debug=0 --app_parameter= --useLCM=0 --datapath=/usr/local/driveworks/data/samples/cgf/trafficlightturning-hyperion8 --mapPath= --path=/home/CGFMultiplierSampleTest/app --virtual=0 > /home/CGFMultiplierSampleTest/logSpace/launcher.log 2>&1
stm_master.log (464 Bytes)
ssm.log (17.0 KB)
schedule_manager_0.log (7.4 MB)
mainClient_0.log (538.4 KB)
launcher.log (21.2 KB)
Dear @sushant.bahadure,
Could you put any prints in node functions to understand if the node passes are called in the log related to the process.
Hi SivaRamaKrishnaNV,
I did found an alternative.
if the launcher was terminated incorrectly for example if it was terminated with sigkill , next run would produce these error.
If the launcher was terminated gracefully with sigInt I could rerun the script with proper dw log prints.
But I do need to restart the container.
I am not sure why it happens, may be some issues with ownership of dw log.
Thanks,
That indicates, subprocess is locking the resources and is not killed. Could you check if any subprocess is active using ps -aux ?
So the qst is,
How to make launcher exit gracefully without a Ctrl-C?
Can you share a useful example?
Take a runHelloworld.sh for example
runHelloworld.sh.txt (12.5 KB)
This issue is related to [BUG] DO6081/CGF 5.14 app cannot exit gracefully: rerun failed, reporting internel errors and require reboot
