¿How can I change my prediction layer to 42 classes instead of 20 in VehicleMakeNet with TAO?
• Hardware: ubuntu 20 x86 with RTX 3060
• Network Type: VehicleMakeNet (Resnet18 backbone)
• TLT Version: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5
• Training spec file:
train_car_make.txt (1.5 KB)
• The issue:
!tao model classification_tf1 train \
-e $SPECS_DIR/train_car_make.txt \
-r $RESULTS_DIR/output \
--key $KEY \
--verbose \
--gpus $NUM_GPUS
I have a train data with 42 classes while my resnet18 pretrained model have 20 output. This is my output log:
2024-07-05 17:14:39,752 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 361: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5
2024-07-05 17:14:39,772 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 293:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/josemi/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
2024-07-05 17:14:39,772 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 301: Printing tty value True
Using TensorFlow backend.
2024-07-05 15:14:40.335109: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2024-07-05 15:14:40,367 [TAO Toolkit] [WARNING] tensorflow 40: Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2024-07-05 15:14:41,063 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2024-07-05 15:14:41,089 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2024-07-05 15:14:41,093 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/utils/helper.py:150: NumbaDeprecationWarning: The 'nopython' keyword argument was not supplied to the 'numba.jit' decorator. The implicit default value for this argument is currently False, but it will be changed to True in Numba 0.59.0. See https://numba.readthedocs.io/en/stable/reference/deprecation.html#deprecation-of-object-mode-fall-back-behaviour-when-using-jit for details.
def random_hue(img, max_delta=10.0):
/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/utils/helper.py:173: NumbaDeprecationWarning: The 'nopython' keyword argument was not supplied to the 'numba.jit' decorator. The implicit default value for this argument is currently False, but it will be changed to True in Numba 0.59.0. See https://numba.readthedocs.io/en/stable/reference/deprecation.html#deprecation-of-object-mode-fall-back-behaviour-when-using-jit for details.
def random_saturation(img, max_shift):
/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/utils/helper.py:183: NumbaDeprecationWarning: The 'nopython' keyword argument was not supplied to the 'numba.jit' decorator. The implicit default value for this argument is currently False, but it will be changed to True in Numba 0.59.0. See https://numba.readthedocs.io/en/stable/reference/deprecation.html#deprecation-of-object-mode-fall-back-behaviour-when-using-jit for details.
def random_contrast(img, center, max_contrast_scale):
/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/utils/helper.py:192: NumbaDeprecationWarning: The 'nopython' keyword argument was not supplied to the 'numba.jit' decorator. The implicit default value for this argument is currently False, but it will be changed to True in Numba 0.59.0. See https://numba.readthedocs.io/en/stable/reference/deprecation.html#deprecation-of-object-mode-fall-back-behaviour-when-using-jit for details.
def random_shift(x_img, shift_stddev):
2024-07-05 15:14:42.160049: I tensorflow/core/platform/profile_utils/cpu_utils.cc:109] CPU Frequency: 2592000000 Hz
2024-07-05 15:14:42.160467: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x83a88e0 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2024-07-05 15:14:42.160488: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version
2024-07-05 15:14:42.161283: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcuda.so.1
2024-07-05 15:14:42.186770: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-07-05 15:14:42.186990: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x81c3c90 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2024-07-05 15:14:42.187009: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): NVIDIA GeForce RTX 3060, Compute Capability 8.6
2024-07-05 15:14:42.187150: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-07-05 15:14:42.187222: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1674] Found device 0 with properties:
name: NVIDIA GeForce RTX 3060 major: 8 minor: 6 memoryClockRate(GHz): 1.807
pciBusID: 0000:01:00.0
2024-07-05 15:14:42.187244: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2024-07-05 15:14:42.187289: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcublas.so.12
2024-07-05 15:14:42.188281: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcufft.so.11
2024-07-05 15:14:42.188333: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcurand.so.10
2024-07-05 15:14:42.190099: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcusolver.so.11
2024-07-05 15:14:42.190644: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcusparse.so.12
2024-07-05 15:14:42.190678: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudnn.so.8
2024-07-05 15:14:42.190736: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-07-05 15:14:42.190843: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-07-05 15:14:42.190901: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1802] Adding visible gpu devices: 0
2024-07-05 15:14:42.190919: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2024-07-05 15:14:42.195246: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1214] Device interconnect StreamExecutor with strength 1 edge matrix:
2024-07-05 15:14:42.195276: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1220] 0
2024-07-05 15:14:42.195285: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1233] 0: N
2024-07-05 15:14:42.195465: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-07-05 15:14:42.195609: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-07-05 15:14:42.195693: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1359] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 8965 MB memory) -> physical GPU (device: 0, name: NVIDIA GeForce RTX 3060, pci bus id: 0000:01:00.0, compute capability: 8.6)
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
2024-07-05 15:14:43,154 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable TF_ALLOW_IOLIBS=1.
WARNING:tensorflow:TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2024-07-05 15:14:43,179 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
WARNING:tensorflow:TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2024-07-05 15:14:43,181 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2024-07-05 15:14:43,952 [TAO Toolkit] [INFO] __main__ 388: Loading experiment spec at /specs/train_car_make.cfg.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:398: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2024-07-05 15:14:43,953 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:398: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:407: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2024-07-05 15:14:43,953 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:407: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2024-07-05 15:14:44,021 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.common.logging.logging 197: Log file already exists at /results/output/status.json
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:431: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
2024-07-05 15:14:44,021 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:431: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:431: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
2024-07-05 15:14:44,021 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:431: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
Found 44959 images belonging to 42 classes.
2024-07-05 15:14:44,588 [TAO Toolkit] [INFO] __main__ 294: Processing dataset (train): /data/car_make_dataset/training_set
Found 9604 images belonging to 42 classes.
2024-07-05 15:14:44,715 [TAO Toolkit] [INFO] __main__ 311: Processing dataset (validation): /data/car_make_dataset/val_set
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:74: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2024-07-05 15:14:44,715 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:74: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2024-07-05 15:14:44,715 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2024-07-05 15:14:44,717 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2024-07-05 15:14:44,732 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:133: The name tf.placeholder_with_default is deprecated. Please use tf.compat.v1.placeholder_with_default instead.
2024-07-05 15:14:44,736 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:133: The name tf.placeholder_with_default is deprecated. Please use tf.compat.v1.placeholder_with_default instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/third_party/keras/tensorflow_backend.py:199: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2024-07-05 15:14:45,215 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/third_party/keras/tensorflow_backend.py:199: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2024-07-05 15:14:45,818 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2024-07-05 15:14:45,818 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2024-07-05 15:14:45,818 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2024-07-05 15:14:46,140 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
2024-07-05 15:14:48,529 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
2024-07-05 15:14:48,531 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2024-07-05 15:14:49,376 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2024-07-05 15:14:49,478 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
__________________________________________________________________________________________________
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 3, 224, 224) 0
conv1 (Conv2D) (None, 64, 112, 112) 9408 input_1[0][0]
bn_conv1 (BatchNormalization) (None, 64, 112, 112) 256 conv1[0][0]
activation_1 (Activation) (None, 64, 112, 112) 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (None, 64, 56, 56) 36864 activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 56, 56) 256 block_1a_conv_1[0][0]
block_1a_relu_1 (Activation) (None, 64, 56, 56) 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (None, 64, 56, 56) 36864 block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 56, 56) 4096 activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 56, 56) 256 block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 56, 56) 256 block_1a_conv_shortcut[0][0]
add_1 (Add) (None, 64, 56, 56) 0 block_1a_bn_2[0][0]
block_1a_bn_shortcut[0][0]
block_1a_relu (Activation) (None, 64, 56, 56) 0 add_1[0][0]
block_1b_conv_1 (Conv2D) (None, 64, 56, 56) 36864 block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 56, 56) 256 block_1b_conv_1[0][0]
block_1b_relu_1 (Activation) (None, 64, 56, 56) 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (None, 64, 56, 56) 36864 block_1b_relu_1[0][0]
block_1b_conv_shortcut (Conv2D) (None, 64, 56, 56) 4096 block_1a_relu[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 56, 56) 256 block_1b_conv_2[0][0]
block_1b_bn_shortcut (BatchNorm (None, 64, 56, 56) 256 block_1b_conv_shortcut[0][0]
add_2 (Add) (None, 64, 56, 56) 0 block_1b_bn_2[0][0]
block_1b_bn_shortcut[0][0]
block_1b_relu (Activation) (None, 64, 56, 56) 0 add_2[0][0]
block_2a_conv_1 (Conv2D) (None, 128, 28, 28) 73728 block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 28, 28) 512 block_2a_conv_1[0][0]
block_2a_relu_1 (Activation) (None, 128, 28, 28) 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (None, 128, 28, 28) 147456 block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 28, 28) 8192 block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 28, 28) 512 block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 28, 28) 512 block_2a_conv_shortcut[0][0]
add_3 (Add) (None, 128, 28, 28) 0 block_2a_bn_2[0][0]
block_2a_bn_shortcut[0][0]
block_2a_relu (Activation) (None, 128, 28, 28) 0 add_3[0][0]
block_2b_conv_1 (Conv2D) (None, 128, 28, 28) 147456 block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 28, 28) 512 block_2b_conv_1[0][0]
block_2b_relu_1 (Activation) (None, 128, 28, 28) 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (None, 128, 28, 28) 147456 block_2b_relu_1[0][0]
block_2b_conv_shortcut (Conv2D) (None, 128, 28, 28) 16384 block_2a_relu[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 28, 28) 512 block_2b_conv_2[0][0]
block_2b_bn_shortcut (BatchNorm (None, 128, 28, 28) 512 block_2b_conv_shortcut[0][0]
add_4 (Add) (None, 128, 28, 28) 0 block_2b_bn_2[0][0]
block_2b_bn_shortcut[0][0]
block_2b_relu (Activation) (None, 128, 28, 28) 0 add_4[0][0]
block_3a_conv_1 (Conv2D) (None, 256, 14, 14) 294912 block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 14, 14) 1024 block_3a_conv_1[0][0]
block_3a_relu_1 (Activation) (None, 256, 14, 14) 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (None, 256, 14, 14) 589824 block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 14, 14) 32768 block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 14, 14) 1024 block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 14, 14) 1024 block_3a_conv_shortcut[0][0]
add_5 (Add) (None, 256, 14, 14) 0 block_3a_bn_2[0][0]
block_3a_bn_shortcut[0][0]
block_3a_relu (Activation) (None, 256, 14, 14) 0 add_5[0][0]
block_3b_conv_1 (Conv2D) (None, 256, 14, 14) 589824 block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 14, 14) 1024 block_3b_conv_1[0][0]
block_3b_relu_1 (Activation) (None, 256, 14, 14) 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (None, 256, 14, 14) 589824 block_3b_relu_1[0][0]
block_3b_conv_shortcut (Conv2D) (None, 256, 14, 14) 65536 block_3a_relu[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 14, 14) 1024 block_3b_conv_2[0][0]
block_3b_bn_shortcut (BatchNorm (None, 256, 14, 14) 1024 block_3b_conv_shortcut[0][0]
add_6 (Add) (None, 256, 14, 14) 0 block_3b_bn_2[0][0]
block_3b_bn_shortcut[0][0]
block_3b_relu (Activation) (None, 256, 14, 14) 0 add_6[0][0]
block_4a_conv_1 (Conv2D) (None, 512, 14, 14) 1179648 block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 14, 14) 2048 block_4a_conv_1[0][0]
block_4a_relu_1 (Activation) (None, 512, 14, 14) 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (None, 512, 14, 14) 2359296 block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 14, 14) 131072 block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 14, 14) 2048 block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 14, 14) 2048 block_4a_conv_shortcut[0][0]
add_7 (Add) (None, 512, 14, 14) 0 block_4a_bn_2[0][0]
block_4a_bn_shortcut[0][0]
block_4a_relu (Activation) (None, 512, 14, 14) 0 add_7[0][0]
block_4b_conv_1 (Conv2D) (None, 512, 14, 14) 2359296 block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 14, 14) 2048 block_4b_conv_1[0][0]
block_4b_relu_1 (Activation) (None, 512, 14, 14) 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (None, 512, 14, 14) 2359296 block_4b_relu_1[0][0]
block_4b_conv_shortcut (Conv2D) (None, 512, 14, 14) 262144 block_4a_relu[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 14, 14) 2048 block_4b_conv_2[0][0]
block_4b_bn_shortcut (BatchNorm (None, 512, 14, 14) 2048 block_4b_conv_shortcut[0][0]
add_8 (Add) (None, 512, 14, 14) 0 block_4b_bn_2[0][0]
block_4b_bn_shortcut[0][0]
block_4b_relu (Activation) (None, 512, 14, 14) 0 add_8[0][0]
avg_pool (AveragePooling2D) (None, 512, 1, 1) 0 block_4b_relu[0][0]
flatten (Flatten) (None, 512) 0 avg_pool[0][0]
predictions (Dense) (None, 20) 10260 flatten[0][0]
Total params: 11,552,724
Trainable params: 11,531,668
Non-trainable params: 21,056
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py:1133: The name tf.summary.FileWriter is deprecated. Please use tf.compat.v1.summary.FileWriter instead.
2024-07-05 15:15:09,531 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py:1133: The name tf.summary.FileWriter is deprecated. Please use tf.compat.v1.summary.FileWriter instead.
2024-07-05 15:15:09,532 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.common.logging.logging 197: Log file already exists at /results/output/status.json
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py:1181: The name tf.summary.merge_all is deprecated. Please use tf.compat.v1.summary.merge_all instead.
2024-07-05 15:15:11,577 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py:1181: The name tf.summary.merge_all is deprecated. Please use tf.compat.v1.summary.merge_all instead.
2024-07-05 15:15:12,396 [TAO Toolkit] [INFO] root 2102: Starting Training Loop.
Epoch 1/3
2024-07-05 15:15:12,821 [TAO Toolkit] [INFO] root 2102: Error when checking target: expected predictions to have shape (20,) but got array with shape (42,)
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py", line 668, in <module>
main()
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py", line 717, in return_func
raise e
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py", line 705, in return_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py", line 664, in main
raise e
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py", line 645, in main
run_experiment(config_path=args.experiment_spec_file,
File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py", line 599, in run_experiment
final_model.fit_generator(
File "/usr/local/lib/python3.8/dist-packages/keras/legacy/interfaces.py", line 91, in wrapper
File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 1405, in fit_generator
return training_generator.fit_generator(
File "/usr/local/lib/python3.8/dist-packages/keras/engine/training_generator.py", line 215, in fit_generator
outs = model.train_on_batch(x, y,
File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 1208, in train_on_batch
x, y, sample_weights = self._standardize_user_data(
File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 784, in _standardize_user_data
y = standardize_input_data(
File "/usr/local/lib/python3.8/dist-packages/keras/engine/training_utils.py", line 134, in standardize_input_data
raise ValueError(
ValueError: Error when checking target: expected predictions to have shape (20,) but got array with shape (42,)
Execution status: FAIL
2024-07-05 17:15:16,631 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 363: Stopping container.
