Char* string parameters in nvmsgbroker.h should be declared const
Jetson / GPU
• DeepStream Version
6.0
4.6
• TensorRT Version
All char* string parameters are missing const keyword.
Include and reference in C++ application.
For those of us using C++, the current function definitions in nvmsgbroker.h force us to cast away the const qualification from all std::string input parameters.
For example
NvMsgBrokerClientHandle   nv_msgbroker_connect(char *broker_conn_str, char *broker_proto_lib, nv_msgbroker_connect_cb_t connect_cb, char *cfg);
ends up getting called as
m_connectionHandle = nv_msgbroker_connect(
    const_cast<char*>(m_connectionString.c_str()),
    const_cast<char*>(m_protocolLib.c_str()),
    broker_connection_listener_cb,
    const_cast<char*>(m_brokerConfigFile.c_str()));
It works… but it’s an ugly workaround.
I’ve used most of your APIs at this point, and I believe this is the only client file that has this const char* omission.
Thanks for your advice!
Looking at your protocol-adapter tests and plugin documentation… seeing all of the dependencies on the current prototype definitions, I’m sure it’s not worth changing at this point.
But, thanks for getting back.
