Check pinmux on spi0&1 on jetson-nano
I referred customizing_the_jetson_nano_40-pin_expansion_header_v1.2.pdf to set up pinmux on Linux_R32.3.1. But I failed to read&write my spi devices after programmed the jetson-nano.
So, Do we have any method to check whether the pinmux had been set correctly?
Got below information from my board, But I don’t know how to interpret them.
root@jetson-2-B01:~# cat /sys/kernel/debug/gpio | grep SPI
gpio-12 (SPI1_MOSI )
gpio-13 (SPI1_MISO )
gpio-14 (SPI1_SCK )
gpio-15 (SPI1_CS0 )
gpio-16 (SPI0_MOSI )
gpio-17 (SPI0_MISO )
gpio-18 (SPI0_SCK )
gpio-19 (SPI0_CS0 )
gpio-20 (SPI0_CS1 )
gpio-232 (SPI1_CS1 )
cat /sys/kernel/debug/tegra_gpio
root@jetson-2-B01:~# cat /sys/kernel/debug/tegra_gpio
Name:Bank:Port CNF OE OUT IN INT_STA INT_ENB INT_LVL
A: 0:0 64 40 40 24 00 00 000000
B: 0:1 f0 00 00 00 00 00 000000
C: 0:2 1f 00 00 00 00 00 000000
D: 0:3 00 00 00 00 00 00 000000
E: 1:0 40 00 00 40 00 00 004000
F: 1:1 00 00 00 00 00 00 000000
G: 1:2 0c 00 00 00 00 00 000000
H: 1:3 fd 99 00 60 00 00 000000
I: 2:0 07 07 03 00 00 00 000000
J: 2:1 f0 00 00 00 00 00 000000
K: 2:2 00 00 00 00 00 00 000000
L: 2:3 00 00 00 00 00 00 000000
M: 3:0 00 00 00 00 00 00 000000
N: 3:1 00 00 00 00 00 00 000000
O: 3:2 00 00 00 00 00 00 000000
P: 3:3 00 00 00 00 00 00 000000
Q: 4:0 00 00 00 00 00 00 000000
R: 4:1 00 00 00 00 00 00 000000
S: 4:2 a0 80 00 00 00 00 000000
T: 4:3 01 01 00 00 00 00 000000
U: 5:0 00 00 00 00 00 00 000000
V: 5:1 03 00 00 03 00 00 000100
W: 5:2 00 00 00 00 00 00 000000
X: 5:3 78 08 08 70 00 60 606000
Y: 6:0 06 00 00 06 00 00 000400
Z: 6:1 0f 08 00 05 00 04 000500
AA: 6:2 00 00 00 00 00 00 000000
BB: 6:3 01 00 00 01 00 00 000000
CC: 7:0 92 80 80 10 00 12 121200
DD: 7:1 01 00 00 00 00 00 000000
EE: 7:2 00 00 00 00 00 00 000000
FF: 7:3 00 00 00 00 00 00 000000
Looks like you didn’t use the r32.3.1, which release BSP do you apply to ?
Hi, Shane
I am using r32.3.1.
The BSP files are Tegra210_Linux_R32.3.1_aarch64.tbz2, Tegra_Linux_Sample-Root-Filesystem_R32.3.1_aarch64.tbz2, public_sources.tbz2.
I am using an jetson-nano board with emmc flash. The jetson-io.py doesn’t work on my board.
The GPIO looks like no correct.
Have a check below.
Hi, Shane
Thanks a lot. But it only enable spidev0.0, and only configure 4 pins, I need enable four spidev. They spidev0.0, spidev0.1, spidev1.0, spidev1.1.
So there are 10 pins to be configured. Could you guide me how to modify u-boot/board/nvidia/p3450-porg/pinmux-config-p3450-porg.h
and kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
Could you check if you can run below command
sudo find /opt/nvidia/jetson-io/ -mindepth 1 -maxdepth 1 -type d -exec touch {}/ init .py ;
sudo /opt/nvidia/jetson-io/jetson-io.py
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide%2Fhw_setup_jetson_io.html
Yes. I had tried this. But it doesn’t help. And I also see jetson-io.py doesn’t support emmc flash on another ticket.
OK, I see.
Then you may need to build the u-boot and follow below patch remove the GPIO(B, x x) these group for the SPI1
https://github.com/gtjoseph/jetson-nano-support/blob/l4t_32.2.1/spi/l4t-sources-u-boot-spidev0-0.patch
I see all the pin are configured as IN . Should we use OUT0 or OUT1 for SPI CLK,MOSI,CSx pins?
Just comment them out, don’t need to configure it no matter as IN or OUT.
And you should be able see the different with the cat /sys/kernel/debug/tegra_gpio
Hi, Shane
I had done below modifications. But I don’t see too much difference in tegra_gpio
Modifications:
cd /home/jetson/Linux_for_Tegra/source/public
vi u-boot/board/nvidia/p3450-porg/pinmux-config-p3450-porg.h
static const struct tegra_gpio_config p3450_porg_gpio_inits = {
GPIO_INIT(B, 4, IN),
GPIO_INIT(B, 5, IN),
GPIO_INIT(B, 6, IN),
GPIO_INIT(B, 7, IN),
GPIO_INIT(DD, 0, IN),
GPIO_INIT(C, 0, IN),
GPIO_INIT(C, 1, IN),
GPIO_INIT(C, 2, IN),
GPIO_INIT(C, 3, IN),
GPIO_INIT(C, 4, IN),
Model: P3448 180-l3448-DAAA-B01
root@yisp-desktop:~# cat /proc/device-tree/nvidia,dtsfilename
/dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
head -n 30 ./hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
#include “tegra210-porg-p3448-common.dtsi”
#include “porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi”
#include “porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi”
vi ./hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
gpio-input = <
TEGRA_GPIO(B, 4)
TEGRA_GPIO(B, 5)
TEGRA_GPIO(B, 6)
TEGRA_GPIO(B, 7)
TEGRA_GPIO(DD, 0)
TEGRA_GPIO(C, 0)
TEGRA_GPIO(C, 1)
TEGRA_GPIO(C, 2)
TEGRA_GPIO(C, 3)
TEGRA_GPIO(C, 4)
vi ./hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
spi2_mosi_pb4 {
nvidia,pins = “spi2_mosi_pb4”;
- nvidia,function = “rsvd2”;
+ nvidia,function = “spi2”;
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
spi2_miso_pb5 {
- nvidia,pins = “spi2_miso_pb5”;
spi2_sck_pb6 {
- nvidia,pins = “spi2_sck_pb6”;
spi2_cs0_pb7 {
- nvidia,pins = “spi2_cs0_pb7”;
spi2_cs1_pdd0 {
- nvidia,pins = “spi2_cs1_pdd0”;
spi1_mosi_pc0 {
- nvidia,pins = “spi1_mosi_pc0”;
+ nvidia,function = “spi1”;
spi1_miso_pc1 {
nvidia,pins = “spi1_miso_pc1”;
- nvidia,function = “rsvd1”;
spi1_sck_pc2 {
nvidia,pins = “spi1_sck_pc2”;
spi1_cs0_pc3 {
nvidia,pins = “spi1_cs0_pc3”;
spi1_cs1_pc4 {
nvidia,pins = “spi1_cs1_pc4”;
How do you flash the u-boot? Have a try the binary from the github to make sure your modification.
Hi, Shane
After do the above modification. I rebuild uboot and kernel. Then use flash.sh to program the board. The steps like below.
2.rebuild
cd /home/jetson/Linux_for_Tegra/source/public/
cd u-boot
export CROSS_COMPILE=/home/jetson/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
make distclean
make p3450-porg_defconfig
make
cp u-boot.bin …/…/…/bootloader/t210ref/p3450-porg/
cd source/public/
cd kernel/kernel-4.9/
export TEGRA_KERNEL_OUT=/home/jetson/kernel_out
export LOCALVERSION=-tegra
make ARCH=arm64 O=$TEGRA_KERNEL_OUT
cp /home/jetson/kernel_out/arch/arm64/boot/Image /home/jetson/Linux_for_Tegra/kernel/Image
cp /home/jetson/kernel_out/arch/arm64/boot/dts/tegra210-p3448-*.dtb /home/jetson/Linux_for_Tegra/kernel/dtb/
3.Then program the board.
./flash.sh jetson-nano-emmc mmcblk0p1
replace bootloader/t210ref/p3450-porg/u-boot.bin with the u-boot-spidev0-0.bin from github.
I see below info:
root@yisp-desktop:/home/yisp# cat /sys/kernel/debug/tegra_gpio
A: 0:0 64 40 40 04 00 00 000000
E: 1:0 40 00 00 40 00 00 000000
V: 5:1 03 00 00 03 00 00 000000
X: 5:3 78 08 08 30 00 60 606000
Y: 6:0 06 00 00 06 00 00 000000
Z: 6:1 0f 08 00 07 00 04 000400
CC: 7:0 92 80 80 00 00 12 121200
Did you remove all of the gpio group B and C from this file …/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi ?
Just check r32.3.1 u-boot already remove the GPIO init code you should be able use original u-boot.bin and remove the GPIO define in the dtsi file that should be working.
Hi, Shane
Thanks for helps. Could you help check whether the below configs are right.
B: 0:1 00 00 00 00 00 00 000000
C: 0:2 00 00 00 00 00 00 000000
Z: 6:1 0f 08 00 05 00 04 000400
DD: 7:1 00 00 00 00 00 00 000000
Now the enable bits of GPIO B and C group are clean. That’s correct now.
Could you attached the dtb here for some others reference.
Hi, Shane
Thanks a lot. The SPI interfaces are working now.
The system doesn’t allow upload dtb file. So I change the file extension to dtb.loggz.
tegra210-p3448-0002-p3449-0000-b00.dtb.loggz (209.5 KB)
Thanks ysp123ysp
I attached the u-boot.bin here for someone need to enable SPI function. Rename it to u-boot.bin and replace the …/Linux_for_tegra/bootloader/t210ref/p3450-porg/u-boot.bin and reflash the device.
u-boot.bin.txt (469.8 KB)
