I would like to launch a project using Chromium to play videos and have an interface using HTML using the Jetson’s GPU. (Jetson Nano)
However, I read that Chromium was not able to use hardware acceleration on this platform.
Is it possible to enable it?
Is this wiki be valid for the Jetson Nano?
(https://elinux.org/Tegra/Downstream_SW/Linux4Tegra/WebBrowsers/Hardware_Accelerated_Video_Decoding)
If hardware decoding isn’t available, would the video be laggy?
How much of the CPU would be used to decode a 1080p@30fps video?
Could other features such as CSS transitions be hardware accelerated?
It would seems like a waste of resources not using the GPU for video decoding.
If the board was not designed for such applications, is there a piece of hardware that would be more adequate for this?
Thank you very much
