Circuitpython PlatformDetector doesn't detect new jetson orin nano super
When I run Detector from adafruit_platformdetect I get board = None. Therefore I cant connect I2C devices like PCA 9685. i2cdetect works fine on bus 1
from adafruit_platformdetect import Detector
detector= Detector()
print ("chip id: ", detector.chip.id)
print ("board id:", detector.board.id)
Terminal output:
chip id: T234
board id: None
It is broken, we are not able to get it running. Only i2c that works is on the pins at the top of the header.
Please consult with vendor for it.
