Clara AGX SDK-Manager Installation failed
The following packages have unmet dependencies:
sdkmanager:amd64 : Depends: libgconf-2-4:amd64 but it is not installable
Depends: libcanberra-gtk-module:amd64 but it is not installable
Depends: locales:amd64 but it is not installable
E: Unable to correct problems, you have held broken packages.
Thanks for joining the NVIDIA Developer forums! I am moving your topic to the Clara category so the team has visibility.
Cheers,
Tom
Thank you.
Hi @ocean0922, I found this post that may be relevant SDK Manager install fail, could you confirm which machine / OS you’re installing SDKManager on?
Hi jinl ,
Clara AGX equipment ,Virtual Machine Installation
Could you please elaborate? Do you mean you are running a VM on Clara AGX, and running SDKM within the VM? Please see the related post’s solution:
