When I tried to install the sdkmanager, I got the error messages:
etlab@ETtestVehicle:~/Downloads$ sudo apt install ./sdkmanager_2.1.0-11682_amd64.deb
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘sdkmanager:amd64’ instead of ‘./sdkmanager_2.1.0-11682_amd64.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sdkmanager:amd64 : Depends: libcanberra-gtk-module:amd64 but it is not installable
Depends: locales:amd64 but it is not installable
Depends: libxshmfence1:amd64 but it is not installable
Depends: libnss3:amd64 but it is not installable
Depends: libatk-bridge2.0-0:amd64 but it is not installable
Depends: libdrm2:amd64 but it is not installable
Depends: libgtk-3-0:amd64 but it is not installable
Depends: libgbm1:amd64 but it is not installable
Depends: libcanberra-gtk3-module:amd64 but it is not installable
Depends: libx11-xcb1:amd64 but it is not installable
E: Unable to correct problems, you have held broken packages.
I’m running Jetson AGX Orin, ubuntu 20.4, following the instruction from:
I tried
sudo apt upgrade
and the same error occurs.
