Could it be possible to run parabricks/4 on H100 gpu? I tried to run docker image, and failed. Since I didn’t see Hopper was mentioned in the doc, I’m wondering if there is some hardware restriction before spending more time troubleshooting it.
docker run --gpus all --mount type=bind,source=/yuq3/parabricks,target=/parab -it nvcr.io/nvidia/clara/clara-parabricks:4.0.1-1 /usr/bin/bash
pbrun fq2bam --ref ./parabricks_sample/Ref/Homo_sapiens_assembly38.fasta --in-fq ./parabricks_sample/Data/sample_1.fq.gz ./parabricks_sample/Data/sample_2.fq.gz --out-bam fq2bam_output.bam
Please visit https://docs.nvidia.com/clara/#parabricks for detailed documentation
[Parabricks Options Mesg]: Checking argument compatibility
[Parabricks Options Mesg]: Automatically generating ID prefix
[Parabricks Options Mesg]: Read group created for /parab/parabricks_sample/Data/sample_1.fq.gz and
/parab/parabricks_sample/Data/sample_2.fq.gz
[Parabricks Options Mesg]: @RG\tID:HK3TJBCX2.1\tLB:lib1\tPL:bar\tSM:sample\tPU:HK3TJBCX2.1
[PB Info 2023-Mar-17 17:19:43] ------------------------------------------------------------------------------
[PB Info 2023-Mar-17 17:19:43] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2023-Mar-17 17:19:43] || Version 4.0.1-1 ||
[PB Info 2023-Mar-17 17:19:43] || GPU-BWA mem, Sorting Phase-I ||
[M::bwa_idx_load_from_disk] read 0 ALT contigs
[PB Info 2023-Mar-17 17:19:49] GPU-BWA mem
[PB Info 2023-Mar-17 17:19:49] ProgressMeter Reads Base Pairs Aligned
[PB Warning 2023-Mar-17 17:19:51][ParaBricks/src/check_error.cu:41] cudaSafeCall() failed at ParaBricks/src/mem_chain_kernel.cu/92: invalid device symbol
[PB Error 2023-Mar-17 17:19:51][ParaBricks/src/check_error.cu:44] No GPUs active, shutting down due to previous error., exiting.
For technical support visit https://docs.nvidia.com/clara/parabricks/4.0.0/Help.html
Exiting...
Could not run fq2bam
Exiting pbrun ...
