I am looking to lock the white balance of a camera to static white balance gains.
In looking through the multimedia API, it seems at first glance that I can use setAwbMode
to change the mode to ARGUS::AWB_MODE_DAYLIGHT
, but the documentation is not detailed and is ambiguous.
The name of the function is “set auto white balance mode,” so does that mean that ARGUS::AWB_MODE_DAYLIGHT
is still an “auto” mode and will adjust gains behind the scenes still, just as AWB_MODE_AUTO
does? Or will it lock the white balance to static gains?
Be aware that some parameters may get auto-tune, including gain-range, digital-gain range, exposure and wb.
Searching this forum you may find some examples for older L4T releases, you would adjust and share for more recent use cases.
I am aware that there are other settings to control auto exposure and analog/digital gain. I am asking specifically about white balance if put in a mode such as ARGUS::AWB_MODE_DAYLIGHT
I’m not sure I follow. Are there examples of how NVIDIA’s auto white balance code handles specific presets in older L4T releases?
hello bhagen55,
after you configure AWB modes, for example, AWB_MODE_DAYLIGHT, it configure the preferred color temperature, auto white balance still running at back-end.
may I know what’s the actual use-case,
you may enable awblock
if you would like to have fixed white balance gains.
thanks
Yes we would like fixed daylight white balance gains.
If I set AwbLock
, then setAwbMode(Argus::AWB_MODE_DAYLIGHT)
, will I have static and repeatable white balance levels?
IE if I use those settings, and I run two recordings, will they both be guaranteed to have the same white balance gains?
hello bhagen55,
why don’t you check Argus samples, /usr/src/jetson_multimedia_api/argus/samples/userAutoWhiteBalance/
you may call Argus::IAutoControlSettings::setWbGains for setting wbGains manually.
We can explore that. We were hoping that the existing presets would make applying a sane static white balance profile easy.
hello bhagen55,
there’s API for setting wbGains, currently, we don’t support command option to change wbGains.
