Clock setting issue on Drive AGX Xavier upon flashing
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[*] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
[*] 1.9.1.10844
other
Host Machine Version
[*] native Ubuntu 18.04
other
I flashed drive agx xavier board using drive software 10.0.I was following the set up video
https://www.youtube.com/watch?v=FhyjhC5rD5g&list=TLGGqtegaOna1wowOTAyMjAyMw
In Xavier A clock is correct but in Xavier B clock changes to default even after trying these methods.
Screenshot from 2023-05-30 11-26-58
Screenshot from 2023-05-30 11-48-26
We tried setting clock through NTP server, Htpdate and Chrony but nothing is working
We tried several methods suggested in
https://askubuntu.com/questions/429306/ntpdate-no-server-suitable-for-synchronization-found
https://askubuntu.com/questions/81293/what-is-the-command-to-update-time-and-date-from-internet
but after few seconds time is setting to some date in 2019.
Can some one help out? This has prevent me from installing things.
Thank you!
Dear @sankal.pattanashetti,
Could you search previous posts in forum on similar topic like Clock setting issue on Drive AGX Xavier upon set up ,
setting correct time on xavier to see if it helps.
Thanks for the help @SivaRamaKrishnaNV .
First I tried methods which are given in this post https://forums.developer.nvidia.com/t/clock-setting-issue-on-drive-agx-xavier-upon-set-up/160969 but got to know that there is no unit related to nv_ptp_master.service in systemd.
nvidia@tegra-ubuntu:~$ systemctl stop nv_ptp_master
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to stop ‘nv_ptp_master.service’.
Authenticating as: , (nvidia)
Password:
==== AUTHENTICATION COMPLETE ===
Failed to stop nv_ptp_master.service: Unit nv_ptp_master.service not loaded.
nvidia@tegra-ubuntu:~$ systemctl list-unit-files | grep nv_ptp_*
nv_ptp_slave.service enabled
Tried this also
https://forums.developer.nvidia.com/t/setting-correct-time-on-xavier/112323
nvidia@tegra-ubuntu:~$ sudo bash /usr/local/sbin/canrtc.sh get
could not get time from dongle
Could not get time from RTC dongle
nvidia@tegra-ubuntu:~$ sudo bash /usr/local/sbin/canrtc.sh set
setting time and date to “0a.33.04.07.16.09.13”
no dongle detected skipping update
Could not set time to RTC dongle
I need to try Aurix board method. How can we connect to aurix console.
Dear @sankal.pattanashetti ,
Please check Sudo minicom -D /dev/ttyUSB3
