Every time I boot into Xavier, it’s time gets reset to something in 2019 and I am unable to correct the time manually.
As I understand, there is PTP service running to synchronize time through the aurix mcu. I am not able to find documentation/resources that explain what conditions must be met for the time sync to work correctly.
Please explain how to do the following:
Turn off PTP sync and set time manually, in case xavier is not connected to the internet
According to this FAQ on nvidia developer forum, first I need to set the correct time on the aurix? How do I connect to the aurix to set the time?
Do I have to do this PTP configuration every time I power cycle the board? Is there any way to avoid doing this every time?
